Re: Problem: Service Engine Soon + ABS Light + Traction Control Light (dan-t)
What codes are you getting?
>Turn key on without starting engine
>Clear your marque
>While holding down options button, press fuel 4 times
>Codes will appear on marque
>after that, pressing options(forward) and trip(back) does it manually.
>David
Re: Problem: Service Engine Soon + ABS Light + Traction Control Light (ScreaminDemon)
it does it sporaticly next time i'll get code thanks alot,from doing search some one had same problem code was a102 circute 150 but they never posted what it was thanks,leaving on a week long trip this morning but i'll check to see what this code is when i get there ...thanks again
