Amsoil dealers, help please.
Old Mar 13, 2003 | 08:26 AM
JoeyG's Avatar
JoeyG
Cruise-In III Veteran
Cruise-In IV Veteran
Default Amsoil dealers, help please.
What is the Amsoil part # for the rear differential fluid to replace the factory in my '01 6spd?
Thanks :thumbs:
Old Mar 13, 2003 | 09:27 AM
JWD01's Avatar
JWD01
Default Re: Amsoil dealers, help please. (JoeyG)
I used Series 2000 75W-90 (part #TGR) in the rear. You'll need 2 Qts. and it has all the additives in it already. I also used their synthetic ATF in the 6 speed ( 4 Qts.). :cheers:
Old Mar 13, 2003 | 10:58 AM
wwashing's Avatar
wwashing
Default Re: Amsoil dealers, help please. (JWD01)
The owner's manual specifies 80W-90. I wonder does it matter? :cheers:
Old Mar 13, 2003 | 11:31 AM
JoeyG's Avatar
JoeyG
Cool thanks :cheers:
Old Mar 13, 2003 | 02:02 PM
pewterhdtop's Avatar
pewterhdtop
You can use either the Series 2000 75W-90 part number TGR-QT (quart) or the synthetic 80W-90 part number AGL-QT (quart).
I recommend the use of the Series 2000 75W-90. It is fully interchangeable with the 80W-90, and is our top of the line product. No additional friction modifiers are required.
For the automatic or MN6 transmission, our synthetic universal ATF is recommended, the part number for that is ATF-QT (quart) or ATF-TP (2 1/2 gallon)
:cheers:
[Modified by pewterhdtop, 11:04 AM 3/13/2003]
To Amsoil dealers, help please.
