HYPERTECH AND 160 DEGREE STAT
Old Mar 13, 2003 | 12:22 PM
jbell28's Avatar
jbell28
Default HYPERTECH AND 160 DEGREE STAT
I JUST PURCHASED A HYPERTECH III, AND PLAN ON CHANGING THE STAT THIS WEEKEN ON MY '99 AT4 Z51 3.15. I TOOK A GLANCE LAST NIGHT TO FIND THE STAT BY JUST FOLLOWING THE RADIATOR HOSE AND MUCH TO MY SURPRISE I COULDN'T SEE IT......CAN SOMEBODY HELP ME....WHERE THE HECK IS THE STAT???? :confused:
Old Mar 13, 2003 | 02:14 PM
corvette Mark's Avatar
corvette Mark
Default Re: HYPERTECH AND 160 DEGREE STAT (jbell28)
passenger side front of engine block, good luck! :)
Old Mar 13, 2003 | 02:35 PM
jbell28's Avatar
jbell28
Default Re: HYPERTECH AND 160 DEGREE STAT (lawless99)
THANKS LAWLESS99.....CAN I SEE IT ON THE BLIND OR DO I HAVE TO REMOVE THE DUCT OFF THE THROTLE BODY TO SEE IT? THANKS AGAIN :flag
Old Mar 13, 2003 | 02:45 PM
Z06 Quin's Avatar
Z06 Quin
Follow the hose from the bottom of the radiator on the passenger side up to the front of the block.....it connects to the T-Stat....it is halfway down on the passenger side of the block. The T-stat makes almost a 90 degree turn towards the passenger side of the car and connects to the hose.
Here's how I changed mine out. I got the car hot, and pulled it onto Rhino ramps. I got a large container to catch all the fluid, and using the pitcock on the lower passenger side of the radiator I drained as much fluid as would come out. I used vice grips to open the pitcock, being careful not to get any hot fluid on me. The reason I did this with the car hot is so the T-stat would be open and drain as much fluid from the block and hose as possible. Once all the fluid had drained, I then disconnected the hose and replaced the T-stat. Some fluid will come out when you do this, but it won't be a whole lot. Hope this helps...
[Modified by Z06 Quin, 1:55 PM 3/13/2003]
Old Mar 13, 2003 | 03:21 PM
AnteVenom's Avatar
AnteVenom
Cruise-In IV Veteran
Daytona Jam 1 Veteran
Default Re: HYPERTECH AND 160 DEGREE STAT (Z06 Quin)
I did my install some what differently.
I prepared the new t-stat and had it handy for when it was needed.
I did not drain any fluid but did place a large trascan lid under the car to catch any coolant that might escape.
I removed the clamp (slid it down the hose) holding the radiator hose to the t-stat.
I propped up the end of radiator hose after separating from t-stat to keep fluid from running out.
I removed both bolts that hold t-stat into block making sure to hold t-stat continuously flush against block.
I then did a qiuck switch pulling old stat off and placing new stat on and flush against block thus preventing any collant from leaking out.
Insert two bolts, tighten down, replace clamp, replace any coolant (minimal) and your done.
Good luck on this somewhat easy mod.
:cheers:
Old Mar 13, 2003 | 05:36 PM
CRAIGVETTE's Avatar
CRAIGVETTE
Veteran: Coast Guard
Senior Member
Cruise-In V Veteran
Default Re: HYPERTECH AND 160 DEGREE STAT (chucschramm)
:iagree: That is how I did it and it only took a few minutes!
Old Mar 13, 2003 | 06:02 PM
Z06 Quin's Avatar
Z06 Quin
Default Re: HYPERTECH AND 160 DEGREE STAT (Craig2000)
I tried it that way the first time, lost alot of fluid.....
To HYPERTECH AND 160 DEGREE STAT
