Help idle problems
Old Mar 14, 2003 | 12:27 PM
rockgt302's Avatar
rockgt302
St. Jude Donor '05
Default Help idle problems
I put some gas in the car the other day, That night it started to run rough. Idle was rough between 500/1000 rpms. When driving it hesitates under light throttle, when I get on it, it feels fine. It also has stalled twice. I ran the tank empty and put in sunoco 94 octane and a bottle of outlaw fuel treatment, but it still isnt right. Does it need some time to run through or could my problem be with the pace maf? Or any other ideas
Old Mar 14, 2003 | 05:01 PM
SushiDave's Avatar
SushiDave
Default Re: Help idle problems (rockgt302)
Have you cleaned and reoiled your Pro Flow filter lately?
Oil on MAF will cause problems you have posted.
Old Mar 14, 2003 | 08:08 PM
rockgt302's Avatar
rockgt302
St. Jude Donor '05
Default Re: Help idle problems (SushiDave)
No I havent, how would I clean the MAF any way.
Old Mar 14, 2003 | 08:45 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
I have a can of spray electrical contact/circuit board cleaner that I have used to clean mine! I just blast the little resistors clean and let the solvent evaporate and put it back in place! Works EVERY TIME! I got mine from an electronic supply wearhouse! It is basically carbontechrocloride (SP?) spray! Any circuit/contact cleaner will work fine. :thumbs:
Bill C
[Modified by Bill Curlee, 7:46 PM 3/14/2003]
Old Mar 15, 2003 | 07:23 PM
rockgt302's Avatar
rockgt302
St. Jude Donor '05
ttt, 100 miles later its getting better. Didnt try cleaning the MAF yet. will try tomorrow. Will a maf cause these problems?
To Help idle problems
