adding electric telescoping wheel
Old Mar 15, 2003 | 08:51 PM
robl45's Avatar
robl45
Default adding electric telescoping wheel
is this something that can be added? the car I'm looking at seems to have everything except for that. could it be missing other things too if it doesn't have that? It has the heads up, its a 99 convertible.
Rob
Old Mar 15, 2003 | 10:03 PM
Miaugi's Avatar
Miaugi
Default Re: adding electric telescoping wheel (robl45)
[QUOTE]...could it be missing other things too if it doesn't have that?.../QUOTE]
Check inside your glove box for all the RPO (option codes) your car has. Write them all down (be carefull, easy to mix up numbers and letters). Then visit this site to see what you have and what you don't.
http://www.c5registry.com/Production/99.htm
Take it from there!
Old Mar 15, 2003 | 10:22 PM
Dave00C5's Avatar
Dave00C5
If it doesn't have that, the memory package is not there either.
Old Mar 16, 2003 | 01:13 AM
corvette dave's Avatar
corvette dave
Default Re: adding electric telescoping wheel (Dave00C5)
I would not bet on that!
Old Mar 16, 2003 | 01:46 PM
revo1059's Avatar
revo1059
St. Jude Donor '11
Not true. I have the memory package and no telescopic wheel.
Though I would like to know if I could add the tele-wheel and how much $$ it would cost
Old Mar 16, 2003 | 08:47 PM
Red Vert 02's Avatar
Red Vert 02
Rob, yes you can install a power telescoping column. I had one installed in my 02 vert. I did not have the memory package on my car. The parts I needed were a telelscoping column, drivers seat power control module with the memory function, and the wire harness to hook up the mpdule to the seat. The column gets its power from the seat module. The last thing you have to do is reprogram the BCM from 001 to 002 to recognize the column. I did not do the installation, it was done by Jason at Team Chevy in Westmont ILL. THe column has worked fine since being installed last August. Cost was about $1,200 parts and labor. The column came from a Corvette bone yard. The module and harness wre ordered thru the dealer parts dept. The tech spent MUCH more time on the car than he charged me for because it was the first time he did one and was taking his time. He did a perfect job, you could never tell its not a factory insatall or that that side of the interior was ever worked on. Hope this helps.
Larry :cheers:
[Modified by Red Vert 02, 7:58 PM 3/16/2003]
Old Mar 17, 2003 | 12:13 AM
90 droptop's Avatar
90 droptop
Default Re: adding electric telescoping wheel (Red Vert 02)
Sounds like a cool mod to invest in..
Old Mar 17, 2003 | 02:25 AM
Jason Blue Boost's Avatar
Jason Blue Boost
Larry, getting the wiring harness this week. We're about to ready to install the new column with my new Vette Essentials steering wheel. :thumbs:
Old Mar 17, 2003 | 08:13 AM
Corvette SSX's Avatar
Corvette SSX
St. Jude Donor '08
That is one expensive telscoping wheel.
Old Mar 17, 2003 | 04:03 PM
Red Vert 02
Default Re: adding electric telescoping wheel (Jason Blue Boost)
Jason good luck on the install. I'm I glad I did it. :cheers:
Old Mar 17, 2003 | 04:22 PM
Red Vert 02
Default Re: adding electric telescoping wheel (CorvetteSS)
It is a lot of money but not out of line for Vette columns. I don't know what C3 tilt and tele columns go for but I have seen mid-year telescoping columns advertised for about $1,200. If Gm had not stopped offering the power telescoping column as a stand alone option I would not have had to go thru all the work. I probably would have also ordered HUD if it was available as a stand alone option. Option packages are fine for those that want alot of options on their car. It can save the customer money. However GM should let the customer order options singally if they so choose. Thanks for letting me vent. It's the only complaint I have about my buying experience. PS I'm glad I bought a 2002 and not 2003. Now you have to take damn near all the extra junk whether you want it or not. :rolleyes:
Old Mar 17, 2003 | 05:00 PM
This will be a nice mod. I sure like my telescoping steering wheel. :thumbs:
To adding electric telescoping wheel
