Need Help! Car overheating ...
Old Mar 19, 2003 | 09:05 AM
TXNC5's Avatar
TXNC5
Default Need Help! Car overheating ...
My coolant temp shot up to 260* this morning. This was after about 22 miles of highway driving. I pulled into a parking lot. I did not see any leaking fluid anywhere. The reservoir has coolant in it (full at a hot temp). I let the car idle for a few minutes and the temp drops like a rock to 220* and stays there (oil temp is around 217). If I try to drive it at all, the temp shoots straight back up.
I did race the car the last Saturday some NA and nitrous runs (ran some 10.90's @ 135). I did drive home (after racing) 40+ miles with no problems.
The car is not misfiring, no leaking fluid, the fans are on, ... What else do I need to look for?
Is my thermostat stuck? Water pump?
Thanks.
Old Mar 19, 2003 | 09:50 AM
vetterdstr's Avatar
vetterdstr
CA Events Coordinator
Default Re: Need Help! Car overheating ... (TXNC5)
Is the coolant circulating? If not your pump may be bad... do you have a large plastic bag stuck in front of your radiator? That can cause those problems too... A bad radiator cap (on the tank) will allow high temps too... my bet is that you have a plastic bag in front of the rad....
vetterdstr :cheers:
Old Mar 19, 2003 | 10:38 AM
twincam47's Avatar
twincam47
Default Re: Need Help! Car overheating ... (vetterdstr)
:iagree:
I bet there is a blockage on the radiator by some large piece of debri. :flag
Old Mar 19, 2003 | 11:11 AM
TXNC5's Avatar
TXNC5
Thanks for the replies. I will go and inspect for debris as I did not do that. I will give an update (or ask for more advice).
Thanks.
Old Mar 19, 2003 | 02:02 PM
Mitch Alsup's Avatar
Mitch Alsup
A) insufficient coolant
B) blocked radiator
C) blocked thermostat
D) water pump
E) water pump belt
Old Mar 19, 2003 | 02:10 PM
angel95135's Avatar
angel95135
If it is because debris on your radiator, contact Valaya racing , they have a solution for that.
Old Mar 19, 2003 | 02:20 PM
tboneinsc's Avatar
tboneinsc
Default Re: Need Help! Car overheating ... (angel95135)
When I had overheating problems I saw one of the fans turning slower than the other. I found a plastic Piggly Wiggly shopping bag wrapped around the fan moter. The C5 underhood is like a moving vacuum cleaner.
Old Mar 19, 2003 | 03:33 PM
TXNC5's Avatar
TXNC5
Well, I had it towed to a shop. The guy said he tested the coolant for hydro-carbons, and that the test was positive? So, that means I have an internal problem like a blown head gasket.
Do I have room to pull my heads with the motor in the car if I have head studs? The motor was out when the heads were put on.
Thanks.
Old Mar 19, 2003 | 05:25 PM
vetterdstr's Avatar
vetterdstr
The engine stays in the car when the heads come off... no need to worry about extra cost there... I hope whatever is wrong with your car it is fixed very soon. :smash:
vetterdstr :cheers:
To Need Help! Car overheating ...
