CV Joints
Old Mar 24, 2003 | 10:23 AM
CP's Avatar
CP
Default CV Joints
Anyone have their rear CV joints go bad?? If so, what did it sound like?
Old Mar 25, 2003 | 12:31 AM
SushiDave's Avatar
SushiDave
Default Re: CV Joints (CP)
Have you checked rear bearing lock down nut torque?
if you are hearing a clunk when taking off check lock down nut :yesnod:
Old Mar 25, 2003 | 01:09 PM
jeanlucpicard's Avatar
jeanlucpicard
SushiDave is correct :iagree: but if you still think your CV is going bad try listening to the sound of your rear wheel area as the car begins to roll from a standing stop and/or as the car slows down to a stop (typically less road noise at those times) - around 5-10mph. If you hear a clickety clickety clickety (no jokes here please) as you are rolling to a stop or starting from a stop then THAT's definitely your CV. :sad:
Another method is to get the car up into the air (preferably not at high speed :lolg: ) - on a lift or jack stands - and grab a half-shaft in both hands and rotate the shaft. If the CV clicks, you may have a problem. Generally the CV will fail because the outer boot has split and allowed dirt/water to enter the bearing assembly of the CV causing it to wear. So look at those black CV boots as well to ensure they are in good shape.
Good luck :cheers:
SAVE THE WAVE :seeya :cheers: :cool:
Old Mar 25, 2003 | 04:05 PM
pewterhdtop's Avatar
pewterhdtop
Default Re: CV Joints (SushiDave)
I don't mean to hijack this thread, but, I have a clunck when I take off and at low speeds. Sounds like I should check the rear bearing hold down nut torque as a simple attempt to remedy this. Since I have no clue where the nut is or what the torque spec is, can someone help me out here??? :confused:
Old Mar 27, 2003 | 04:53 AM
SushiDave's Avatar
SushiDave
Default Re: CV Joints (pewterhdtop)
Sounds like you better check torque :yesnod:
Remove rear wheel you will see if I remember correctly 1 1/2 inch bearing lock down nut. Torque to 125 FT LBS.
To CV Joints
