Independently Minded DIC problem
Old Mar 25, 2003 | 04:21 AM
w8d4it's Avatar
w8d4it
St. Jude Donor '04-'05-'06-'07-'08-'09
Default Independently Minded DIC problem
The low washer fluid light came on. I filled the tank and pressed reset on the DIC. But the low washer fluid light continues to come on every time I start the car. Any ideas why and whats the cure. Car is a 2002 Z06
Old Mar 25, 2003 | 08:58 AM
SeaFive's Avatar
SeaFive
Default Re: Independently Minded DIC problem (w8d4it)
I've seen this issue before here, and believe it has been diagnosed as either:
1) loose connection at the low washer fluid sensor located at the bottom of the resevoir
or
2) faulty sensor
This should be a warranty item for your car :cheers:
Old Mar 25, 2003 | 01:03 PM
laramr's Avatar
laramr
Active Streak: 90 Days
My DIC has been known to have a mind of it's own from time to time as well!
:jester :D
Old Mar 25, 2003 | 11:58 PM
w8d4it's Avatar
w8d4it
COME ON DOESN'T ANY ONE HAVE ANY REAL ANSWERS
To Independently Minded DIC problem
