Right brake lights won't work! Help!
Old Mar 25, 2003 | 02:30 PM
TLewis4095's Avatar
TLewis4095
Default Right brake lights won't work! Help!
It's a 98, and the right blinker works fine....but the brake light or 4 way flasher it does not??? Real puzzle....that they work with the turn signal, but not the brakes or 4-ways. Left brake light & the center one work fine.... All fuses appear to be good (unless I missed one) Any ideas ?? Thanks in advance.
Old Mar 25, 2003 | 02:40 PM
kp's Avatar
kp
Default Re: Right brake lights won't work! Help! (TLewis4095)
most likely turn signal switch if all wiring, bulbs and connectors are OK. Could be something with the hazard switch as well. Service manual and a test light would be a good thing to have :cheers:
Old Mar 25, 2003 | 07:53 PM
TLewis4095's Avatar
TLewis4095
Default Re: Right brake lights won't work! Help! (kp)
Now the dang thing is working fine! :confused: :crazy: weird.....
Old Mar 25, 2003 | 08:43 PM
Red C5's Avatar
Red C5
I have the same problem. I have posted this question here 2 or 3 times and got no help. Good luck. I still do not have brake lights on the right side. :mad
Old Mar 26, 2003 | 08:36 AM
SAXN8R's Avatar
SAXN8R
Sounds like the wiring harness is bad. Do you have a euro set up or is it stock? I had a euro wiring harness go bad, replaced it pretty easily and my problems were gone. The stock harness might be a little harder to replace, but I would bet that is your problem. You might try getting some electrical contact cleaner and unplugging the harnes to clean the contacts. It plugs in just above the muffler behind the right rear tire. Watch out for the muffler if your car is hot! That plug is in a bad spot. It get's alot of heat and road debris/water when driving.
Good luck!
Old Mar 26, 2003 | 07:13 PM
TLewis4095's Avatar
TLewis4095
Default Re: Right brake lights won't work! Help! (SAXN8R)
Good advice! Ill check it, it is coming & going now. Stock harness. :cheers:
To Right brake lights won't work! Help!
