Double Roller Timing chains?????
Old Mar 26, 2003 | 10:38 AM
Shinobi'sZ's Avatar
Shinobi'sZ
Default Double Roller Timing chains?????
At what power level should one consider putting on a double roller? Who has got them forsale?
Thanks!
Old Mar 26, 2003 | 11:11 AM
NEPTUNEBILL's Avatar
NEPTUNEBILL
Default Re: Double Roller Timing chains????? (Shinobi'sZ)
Kevin if you talk to wade he uses a good one, that are in the $175 to 200 range, I bought a cloyes fire hardened gear double roller that was $400, when you see the competition set you will be surprised and wonder what kind of flimsy crap comes in the car, deff recomment at your power levels, after seeing the stock one and the new one I'm terrified at the thought of not having one for just my H/C package.
Old Mar 26, 2003 | 12:12 PM
sacsrpc's Avatar
sacsrpc
Default Re: Double Roller Timing chains????? (NEPTUNEBILL)
I am runnning the SLP(rollmaster) double chain on my car. Check out sdpc, I think they have them for less than $100 :cry (I paid $165).
Definitely a worthwhile mod for anyone spinning their engine past the stock rev limit,,,,the stock chain is a pos.
Old Mar 26, 2003 | 02:30 PM
NEPTUNEBILL
Default Re: Double Roller Timing chains????? (sacsrpc)
:iagree: SLP makes one that comes with some kind of spacer for the oil pump as well for about 165.
Old Mar 26, 2003 | 03:31 PM
SFVetteman's Avatar
SFVetteman
I’m running the Rollmaster double roller chain from SPDC. I consider it cheap insurance. They have two models. The standard model sells for $65 that includes a German made chain, billet steel gears, and oil pump spacers. The crank gear can be mounted in 9 different positions to adjust timing. For $20 more a heat-treated model with a Torrington bearing on the cam gear is available. According to MMS who installed my H/C, some machining of the timing case cover was necessary for clearance.
Old Mar 26, 2003 | 05:59 PM
JR-CRUZN-C5's Avatar
JR-CRUZN-C5
Get Cloyes True Roller (The Expensive ones) Can't go wrong Drag Guys all over the country running big big HP motors with them!!!!!!!!!!!!!!!!!!!!!!!!!!
JR :thumbs: :thumbs: :thumbs: :thumbs: :thumbs: :thumbs: :thumbs: :thumbs:
Old Mar 26, 2003 | 06:24 PM
gojo's Avatar
gojo
For me it was one of those "might as wells since we were in there" It is so important and hard to get at. http://www.kbengineparts.com/mainpage.html
Very good price here for the Rollmaster.
Old Mar 26, 2003 | 09:16 PM
Shinobi'sZ's Avatar
Shinobi'sZ
Default Re: Double Roller Timing chains????? (jfpilla)
Damn man..I just bought the SLP double roller from a vendor...and I think it was $169.00. SHOOT! It has the adjustable timing gear too.
Old Mar 26, 2003 | 10:14 PM
Chris@East Coast Supercharging's Avatar
Premium Supporting Vendor
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In V Veteran
You cant go wrong with the Roll Master sold by SLP.. its a nice chain.. :seeya
Old Mar 26, 2003 | 10:28 PM
Shinobi'sZ's Avatar
Shinobi'sZ
Default Re: Double Roller Timing chains????? (CHRIS NJ C5)
Thanks for the reassurance Chris! :cheers:
Old Mar 26, 2003 | 10:56 PM
pkmoose's Avatar
pkmoose
:iagree: with Chris NJ C5
[Modified by pkmoose, 10:56 PM 3/26/2003]
To Double Roller Timing chains?????
