LS1 to LS6 PCV system conversion howto inside
Old Mar 26, 2003 | 05:04 PM
jmX's Avatar
jmX
Default LS1 to LS6 PCV system conversion howto inside
I finally did the LS6 PCV conversion on my 99 LS1. Total cost was about $65, you only have to buy 2 GM parts (there was a list of four parts floating around the net, 2 of which you dont need!), and 10" of fuel line hose. The whole job took me 4 hours from start to finish (I did it one night after work, and this car is my daily driver), and I'd never done it before nor did I know how much to grind off. It should be pretty quick for anybody to do now with the full set of instructions.
The LS6 system definitly appears as if it'll at least get rid of a portion of the PCV oil consumption, I'll have to see how my car is down the road. The main reason I did it was because it was cheap, and I didn't like the LS1 style PCV hose taking up the very little amount of space I have between my firewall and my intake manifold (its really tight on a C5, more so than an F-body).
Anyway, here it is....pass it along if you see somebody that needs it.
http://www.ls1howto.com/index.php?article=18
As usual, if you see errors or have suggestions, email me.
Old Mar 26, 2003 | 05:28 PM
97C5ENVY's Avatar
97C5ENVY
Default Re: LS1 to LS6 PCV system conversion howto inside (jmX)
Great write up Jon!:cheers: This difinitly looks better then having a crapy filter hanging off the engine.
Do you or anyone else know if this LS6 PCV system is better then the filter for keeping oil out of the intake? I'm asking because if it is then by all means this will be my next undertaking.
Old Mar 26, 2003 | 05:50 PM
itsonlyairandfuel's Avatar
itsonlyairandfuel
I have both the LS6 baffle set up and the in line filter. The filter still picks up oil.
Old Mar 26, 2003 | 06:12 PM
LoneStarFRC's Avatar
LoneStarFRC
Default Re: LS1 to LS6 PCV system conversion howto inside (97C5ENVY)
Excellent write-up! :thumbs: Very well done and very thorough too. I'll be doing this mod in the very near future along with a new Z06 intake manifold install. (Might as well kill two birds with one stone.) Keep us posted on any changes in the oil consumption department too.
Robert :)
Old Mar 26, 2003 | 08:06 PM
jmX's Avatar
jmX
This mod will definitly still allow oil to be sucked up, however it should be reduced a bit. I'll be taking off my intake manifold in a week or so to see how filthy it is. One of the main reasons I did this was to get rid of the PCV hose that snaked behind the intake manifold (there's not much space back there!). The LS6 setup is just cleaner and simpler.
Old Mar 26, 2003 | 08:37 PM
geekracer's Avatar
geekracer
Nice Job :thumbs: :cheers:
Old Mar 27, 2003 | 05:19 PM
jmX's Avatar
jmX
Default Re: LS1 to LS6 PCV system conversion howto inside (MMarquez)
Thanks :cheers:
Old Mar 28, 2003 | 01:58 PM
bgood's Avatar
bgood
Cruise-In IV Veteran
St. Jude Contributor
Thanks for the write-up. I see this as a fun project to do sometimes over the next few months.
:cheers:
Old Mar 28, 2003 | 02:11 PM
Closer_2001's Avatar
Closer_2001
First Class as always JMX
Old Mar 28, 2003 | 06:43 PM
AllCammedUp's Avatar
AllCammedUp
Jon,
Thanks a lot for taking the time to write this up and document it so well. Now that I've seen what is involved with it, I'm not apprehensive about doing it to my car.
Thanks again man, your site is a great resource!! :cheers:
Old Mar 28, 2003 | 06:56 PM
Toyride's Avatar
Toyride
Thanks for the info. That will be my next mod along with a fuel pressure regulator, my last mod. HA! HA!HA!
To LS1 to LS6 PCV system conversion howto inside
