C5 Lowering Instructions
Old Mar 31, 2003 | 08:28 PM
mshipon's Avatar
mshipon
Cruise-In I Veteran
Default C5 Lowering Instructions
I know that these must have been posted before, but I'd appreciate it if someone would please direct me to instructions for lowering my '98 coupe. Would it be alright to lower the rear about 1/2" and leave the front alone? I don't want to rub going over every bump and curb.
Thanks.
Old Mar 31, 2003 | 08:36 PM
Dale RED 98's Avatar
Dale RED 98
Default Re: C5 Lowering Instructions (mshipon)
Here you go! http://forums.corvetteforum.com/zerothread?id=311973
Old Mar 31, 2003 | 08:44 PM
SteveL2's Avatar
SteveL2
Default Re: C5 Lowering Instructions (Dale RED 98)
Great link, and nice write up by darkmercury. :cheers: Hmmm, maybe I'll have to take a shot at this. :crazy:
Old Mar 31, 2003 | 08:47 PM
Racer's Avatar
Cruise-In III Veteran
St. Jude Donor '11
You might like this Powerpoint presentation. http://www.members.shaw.ca/superchargedvette/Tips.htm
Old Mar 31, 2003 | 08:58 PM
mshipon's Avatar
mshipon
Cruise-In I Veteran
Thanks guys. That's a lot of stuff to study. I'd like to add to this spring's mod list.
Old Mar 31, 2003 | 09:05 PM
VolFan615's Avatar
VolFan615
Yellow C3/C5
St. Jude Donor '05-'06
Are there any problems lowering a car with the Z51 suspension?
Old Apr 3, 2003 | 02:00 AM
Monster231's Avatar
Monster231
Default Re: C5 Lowering Instructions (VolFan615)
TTT, im also waiting for this, Will there be any issues lowering a Z51, is it the same procedure,
Old Apr 3, 2003 | 01:28 PM
MTWallet's Avatar
MTWallet
Default Re: C5 Lowering Instructions (Monster231)
Z51 doesn't matter, although it might not drop as much due to the stiffer Z51 suspension. If its not low enough, you will have to put longer bolts in the rear and cut a bushing or two in the front.
Old Apr 3, 2003 | 01:57 PM
Leadfoot77's Avatar
Leadfoot77
Would it be alright to lower the rear about 1/2" and leave the front alone.
I would also lower the front too...I've heard from some people that it is unsafe to travel at high speeds if the front is higher than the back due to aerodynamics issues...Just lower both ends...you'll get used to the air dam scraping over bumps. Also, you should plan on getting the AndA rocker rails and frame savers for xtra protection. :yesnod:
Old Apr 5, 2003 | 12:44 AM
MTWallet's Avatar
MTWallet
Default Re: C5 Lowering Instructions (racer44)
This PowerPoint presentation is nice and probably took a lot of time, BUT you DO NOT have to remove any "supporting hardware" in the front to adjust the lowering bolts. He says to disconnect the front swaybar and lower ball joint! All you need to do is raise the front and support it on the subframe crossbrace, then put a small bottle jack under the leaf spring and lift it ever so slightly to take tension off of the bolt. You can then turn it by hand until it stops. If its a little tight, put a socket on it and you're done in a few minutes on each side. I just think he went a little overboard, thats all.
You don't even need to remove anything to cut the front bushings either. There is plenty of room between the spring and lower control arm to slide a course hacksaw blade in there and cut the bushings in about 5 minutes per side.
Old Apr 5, 2003 | 09:43 AM
RUGBY's Avatar
RUGBY
Default Re: C5 Lowering Instructions (MTWallet)
:banghead: :banghead: :banghead: :banghead: :banghead: :banghead: :banghead: :banghead: :banghead: :banghead: :banghead: :banghead:
I tried for about 3 hours to get the freaking A-Arm to drop and you are saying
that I do not need to!!!!!!!!!! :cuss :mad :cuss :mad
What size blade fits in there?
Old Apr 5, 2003 | 11:01 AM
NavyC5's Avatar
NavyC5
CI 3-4-5-6-10 Veteran
St. Jude Donor '03-'06-'08-'09-'10
Default Re: C5 Lowering Instructions (Leadfoot77)
I did a full drop on the rear of my car and left the front alone. No problems at all. :yesnod:
Old Apr 5, 2003 | 11:42 AM
C5stein's Avatar
0C5stein
Former Vendor
Default Re: C5 Lowering Instructions (RUGBY)
Yep, Emptywallet is right. It was a beautiful presentation, but makes a 1/2 hour job into a 1/2 day job.
A little penetrating oil on the threads of the front adjusting bolt and some silicone lube shot between the rubber bushing of the adjusting bolt and lower control arm can make the job even easier. I've never experienced any additional problems lowering a Z51. Actually the F45 shocks get a bit in the way for reaching the adjusting bolts. If you haven't gotten a wheel alignment in the past 10k miles, I would recommend that you get one after you finish lowering your car. I also have rocker savers, spoiler skirt stiffeners and radiator support skid plates on my car as some speed bumps and driveways can really reach up and bite the underside of your car.
Now get out there and get after it. It isn't that hard and you will love the looks of the car when you are done.
Old Apr 5, 2003 | 10:34 PM
boost2much's Avatar
boost2much
Default Re: C5 Lowering Instructions (C5stein)
So I was thinking :D If I lowered my car, the camber would be off. But wouldn't it be kinda like the Z06 aligment :D or am I totally off.
Old Apr 5, 2003 | 11:25 PM
MTWallet's Avatar
MTWallet
Matt, you can get to the bushings through the big cutout area in the lower A-arm. (see picture below) You need to get under the car to get in there, but works great! Just be sure to use a small jack to slightly raise the spring to take the pressure off of the bushing.
[Modified by MTWallet, 10:40 PM 4/5/2003]
Old Apr 5, 2003 | 11:58 PM
corvette dave's Avatar
corvette dave
It would seem that the bushing would not be flat if you cut the bushing without removing the bolt. Flat as it was stock. I would prefer that the bushing rest as much rubber on the spring as possible.
I cut my front bushings and then filed/grinded them as smooth as I could get them. Hard to cut them straight even off the car.
I could be wrong here. Let me know.
Dave
Old Apr 6, 2003 | 12:05 AM
camiv's Avatar
camiv
What does this cost if done at a shop. Anyone recently pay to have it done?
To C5 Lowering Instructions
Old Apr 6, 2003 | 03:52 PM
RUGBY's Avatar
RUGBY
Alrighty guys round two begins here in a few. I will let you all know!
Thanks! :cheers:
Old Apr 6, 2003 | 06:38 PM
Cajun @ Edgyvette's Avatar
0Cajun @ Edgyvette
Former Vendor
St. Jude Donor '07-'08-'09-'10-'11-'12'-'13-'14-'15
Just dropped mine this weekend. Here is the link.
http://hometown.aol.com/ccajun4real/CORVETTE.html
Old Apr 6, 2003 | 08:07 PM
veXati0n's Avatar
veXati0n
