Bleed brakes now have a few problems..
Old Apr 3, 2003 | 10:28 PM
Phil97SVT's Avatar
Phil97SVT
Default Bleed brakes now have a few problems..
Today I was bleeding my brakes and after I was all finished my brake light stays bright, I have a weird DTC code TCS c1247 and my traction control button wont work. Any ideas? I have looked for this code and can't find it anywhere.
Phillip
Old Apr 3, 2003 | 10:41 PM
66ImpalaLT1's Avatar
66ImpalaLT1
Default Re: Bleed brakes now have a few problems.. (Phil97SVT)
Service manual says:
Brake Pressure Differential Switch Activated.
The important thing I gathered from the 2 pages about the code was:
DTC C1247 could be set during a hydraulic brake system bleeding procedure if the ignition switch is in the ON position.
Eric
Old Apr 3, 2003 | 10:56 PM
Phil97SVT's Avatar
Phil97SVT
Default Re: Bleed brakes now have a few problems.. (66ImpalaLT1)
Ok that makes complete sense, how do I turn the code off? I use the DTC to delete it and it pops back up....
Phillip
Old Apr 3, 2003 | 11:00 PM
kwik8racr's Avatar
kwik8racr
I am getting ready to bleed my brakes on saturday, does this mean to make sure the key is off when bleeding? Let me know if there is anything else I should know about. Hope you get yours all figured out Phil! Always seems to be something, doesn't it!? :cuss
Old Apr 3, 2003 | 11:14 PM
66ImpalaLT1
I think it means you still have air in the system. The service manual isnt that clear on what to do unless the pressure sensor itself has failed.
They do have a procedure to bleed the master cylinder if thats suspected to be the problem, and they also say to Auto bleed the ABS modulator with a Tech-2 if the pedal is spongy.
Eric
Old Apr 4, 2003 | 01:47 AM
MRWHOOPPEE's Avatar
MRWHOOPPEE
Try cracking the lines at the master first a few times.
Did it ever run dry ?
If so ....uh , oh.....
Old Apr 4, 2003 | 02:45 AM
vetterdstr's Avatar
vetterdstr
CA Events Coordinator
Take it to a shop and have it power bled... that could straighten it out... :yesnod:
vetterdstr :cheers:
Old Apr 4, 2003 | 05:46 AM
vettenuts's Avatar
vettenuts
Default Re: Bleed brakes now have a few problems.. (vetterdstr)
I had something similar on my C4 once. I pumped the pedal hard a few times and it eventually cleared. I think I would crack one wheel and bleed a few pumps with no key in the ignition.
Old Apr 4, 2003 | 02:46 PM
Phil97SVT's Avatar
Phil97SVT
Update:
I cycled around each corner pumping the brakes one time and once each corner had been rebleed, I pressed on the brakes hard and the problem dissappeared.
Phillip
Old Apr 4, 2003 | 02:58 PM
aaaa's Avatar
aaaa
Thanks!!!!!!!!!!!!!! The pic is great!
To Bleed brakes now have a few problems..
