NEED YOUR INPUT ON HP & SHIFT POINT
Old Apr 5, 2003 | 11:19 PM
C5-JIM's Avatar
C5-JIM
Default NEED YOUR INPUT ON HP & SHIFT POINT
I HAVE NOT HAD A CHANCE TO DYNO THE CAR SO I DON'T KNOW WHAT RPM RANGE TO SHIFT AT,M6. I HAVE THESE MODS- LS6 INTAKE-PORTED THROTLE BODY-PRO TEC MAS-HALL TEC BOTTOM FEEDER-TPIS LT HEADERS-COMP CAM 218-222 558-562-114+2 DEG-STAGE2 HEADS 2.02-1.57 MANLEY SS-C MOLY PR-TIT RET-918 SPRINGS- MILLED .30-NO CATS-X PIPE-FLOWMASTER EXAST. HORSEPOWER ? SHIFT POINT ? ANY INPUT WILL BE HELPFUL, THANKS VERY MUCH. C5JIM :confused: :confused: :confused:
Old Apr 5, 2003 | 11:42 PM
XCELER8's Avatar
XCELER8
Default Re: NEED YOUR INPUT ON HP & SHIFT POINT (C5-JIM)
I have pretty much the same setup, but my cam is a Comp 224/.581/113 and the highest rev that I should be able to achieve after tuning will be around 6400ish from what was told to be from my tuner. I get my tuning next week. With the mods you have you should 420ish rwhp.
Jon
Old Apr 6, 2003 | 11:11 AM
C5-JIM's Avatar
C5-JIM
THANKS FOR THE REPLY. C5-JIM
Old Apr 6, 2003 | 11:25 AM
Richin Chicago's Avatar
Richin Chicago
I have always felt that shift point should always be at redline. The engine then falls right back into the fat part of the HP curve for the higher gear.
To NEED YOUR INPUT ON HP & SHIFT POINT
