stock air bridge removal ???
Old Apr 6, 2003 | 03:39 PM
Z06 Fever's Avatar
Z06 Fever
Cruise-In III Veteran
Cruise-In IV Veteran
Default stock air bridge removal ???
What's the secret to removing the stock air bridge? I loosened the clamps at each end and got the corrugated hose off the throttle body, but can't get the other end away from the MAF. Help!
Old Apr 6, 2003 | 04:35 PM
Crushinator's Avatar
Crushinator
Default Re: stock air bridge removal ??? (Yellow Fever)
Wiggle it back and forth. It'll come off. There's really no secret, just patience.
Old Apr 6, 2003 | 04:51 PM
DsC5's Avatar
DsC5
Default Re: stock air bridge removal ??? (Nat02Z06)
:iagree: make sure everything's loose and give it some time. :seeya
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
The MAF to airbridge fit is very tight and well sealed..but it does just pull apart. WD40 sprayed around the area may help, but theres no secret trick to it.
If you're replacing the bridge, getting the new one into the MAF is even more fun.
:cheers:
Old Apr 6, 2003 | 05:15 PM
Crushinator
Default Re: stock air bridge removal ??? (Y2Kvert4me)
To reassemble it, I found it's actually easier to remove the whole intake system, put everything together loosely, then reinstall it and tighten everything up.
Old Apr 6, 2003 | 07:23 PM
Z06 Fever's Avatar
Z06 Fever
Thanks guys. I wasn't quite sure how well sealed it was and didn't want to break something. I have a decal for the emblem on the air bridge that I wanted to put on, but I might wait until I get the Blackwing and do it then. :cheers:
To stock air bridge removal ???
