Headlight squeak
Old Apr 7, 2003 | 07:03 PM
BobbyD's Avatar
BobbyD
Default Headlight squeak
Closing the headlights gives a loud squeal. Sounds like weatherstripping. Anybody experience this?
Old Apr 7, 2003 | 07:47 PM
WhiteC5Vette's Avatar
WhiteC5Vette
St. Jude Contributor
Default Re: Headlight squeak (BobbyD)
Oh yes, but it is fixable in about ten minutes. Open the hood and manually open the headlamps, remove the black plastic bezel (3 screws), and shoot some high-temp grease on to the four pivot points, where they pivot onto the headlamp. If you use a bright flashlight to shine in you will see the pivot points.
So far, my lube job has lasted four months.
Old Apr 7, 2003 | 08:21 PM
EWill3rd's Avatar
EWill3rd
Default Re: Headlight squeak (WhiteC5Vette)
:iagree:
I use super lube but they key is just to lubricate the pivot points on the headlamp door linkage.
EWill
Old Apr 7, 2003 | 09:42 PM
shafman1's Avatar
shafman1
Default Re: Headlight squeak (EWill3rd)
My left head light makes that noise. At least when it's cold. Thanks for the "head's up." I'll try the fix on mine. :smash:
Old Apr 8, 2003 | 04:04 AM
MyFirst's Avatar
MyFirst
Default Re: Headlight squeak (shafman1)
My car did the same thing and I tried the wd-40 treatment to no avail. I finally brought it to the dealer and had him reaplce both. Having them replace both is very important because one side will go down quicker than the other if only one side is replace. Anyway, apparently it is an expensive piece. I would have the dealer replace the part if it continues to be a problem.
Old Apr 8, 2003 | 06:58 AM
GLF's Avatar
GLF
Default Re: Headlight squeak (MyFirst)
Hey, I've had this intermittently, too! It is pretty seldom, so I haven't worried about it much. I've been there, done that with the WD-40. I'll keep in mind about the grease the next time it pops up!
Old Apr 8, 2003 | 10:04 AM
BobbyD's Avatar
BobbyD
Default Re: Headlight squeak (GLF)
Thanks guys!
Old Apr 14, 2003 | 11:54 AM
BobbyD's Avatar
BobbyD
Tried to solve this problem this weekend. What is the black plastic bezel? The black plastic that wraps all around the side of the assembly? The one that has a cap on it?
Old Apr 14, 2003 | 07:44 PM
texasredc8's Avatar
texasredc8
Yes thats it. You can actually lube the pivot points without removing this by having the headlight assembly lowered. I use an aerosol lithium grease. Its much easier to lube if your assembly is squeeking so you know you hit the right spot. Just have the lights lowered all the way, then manually raise them enough to get the slack in the system, then move them up and down, while spraying a bit and listening to the squeek.
Its usually worse in cold damp weather.
Old Apr 15, 2003 | 09:14 AM
WhiteC5Vette
Default Re: Headlight squeak (TexasRedZ06)
Recommendation, do not use WD-40, use a good grade lithium grease of Teflon lubricant. The lubricant qualities of WD-40 dissipate quickly. WD-40 is a great moisture remover, and it works great to remove bugs from the front fascia, but as a true long-term lubricant, it is terrible.
To Headlight squeak
