Help??? How many head bolts do I need to order?
Old Apr 8, 2003 | 06:30 PM
dave777's Avatar
dave777
St. Jude Contributor
Default Help??? How many head bolts do I need to order?
My 2X kit is on the way from Cartek. I went to order my head gaskets and head bolts from my dealer and they said that there is a set of 16 long bolts and a set of four short bolts. Which ones and how many of each do I need for both heads? Any other gaskets I need?
Old Apr 8, 2003 | 07:06 PM
Redline Motorsports's Avatar
Redline Motorsports
Default Re: Help??? How many head bolts do I need to order? (dave777)
You need the following;
Long Head Bolts (Qty 16) part # 12560744
Medium Bolts (Qty 4) part # 12560745
Shorts (Qty 10) part # 12558840
Call Dave about the proper head gaskets.
I suggest changing the timing chain part # 12552954 or by a Rollmaster.
You will also need a new crank bolt part # 12557840.
All other gaskets can be re-used by inspect them prior to installation.
Old Apr 8, 2003 | 09:12 PM
dave777's Avatar
dave777
Anyone else?
Old Apr 8, 2003 | 11:02 PM
Chris@East Coast Supercharging's Avatar
Premium Supporting Vendor
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In V Veteran
You could always stud the block :D
Old Apr 9, 2003 | 03:33 AM
C5B's Avatar
C5B
Default Re: Help??? How many head bolts do I need to order? (CHRIS NJ C5)
:iagree: ARP head studs..... easy to install and no dumb-azz stretching program - just 3-step torque it and go. Be carefull about the final torque, though. Some of the how-tos suggest 70ft-lb as final torque, but ARP says 65 for aluminum applications.
- C5B
Old Apr 9, 2003 | 10:58 AM
jmX's Avatar
jmX
Anyone else?
The answer above is correct, except you dont need the 10 small bolts. They are reusable.
If you look at my site, it lists what you need. http://www.ls1howto.com/index.php?article=1
As you can see, I list the part number GM 12498545, which is a headbolt kit. It contains all bolts needed for one head. Buy 2 of those part #'s from a dealership.
Old Apr 9, 2003 | 11:10 AM
Phil97SVT's Avatar
Phil97SVT
Default Re: Help??? How many head bolts do I need to order? (jmX)
I would go ahead and spend a few extra dollars and get ARP bolts or studs, never have to replace them again.
Phillip
To Help??? How many head bolts do I need to order?
