adjusting window pitch for pass. side window?
Old Apr 9, 2003 | 08:36 AM
1FUNC5's Avatar
1FUNC5
Default adjusting window pitch for pass. side window?
can anyone give directions to pull off door panel and adjust pitch on the window.... the glass isnt going all the way up into the gasket.....dealer told me this is what will fix it, but i dont usually let other people work on my car....detailed inst. or possibly a fax out of the manual would be nice.... all help on this is greatly appreciated....
Steven Pope
Old Apr 9, 2003 | 05:47 PM
davidfarmer's Avatar
davidfarmer
Default Re: adjusting window pitch for pass. side window? (1FunC5)
The only bolts holding the door panel on are around the door release. Pop the retainer out of the way, the remove the 2 torx bolts. Then, just snap all of the plug fasteners out around the panel. The top of the panel hooks over the top of the door, and I find rolling the window down helps, but remember to roll it backup before disconnecting the wiring.
There is a 10mm nut in the middle of the door that adjusts the tilt of the door tracks. It should be pretty simple to rotate the bottom out/top in to fix your problem.
Dave
Old Apr 10, 2003 | 11:04 AM
rev4679's Avatar
rev4679
Default Re: adjusting window pitch for pass. side window? (davidfarmer)
there are detailed instructions on this site.
http://www.***-internet.com/johndenn...to/how_to.html
To adjusting window pitch for pass. side window?
