low coolant sensor
Old Apr 9, 2003 | 09:38 PM
c5bubba's Avatar
c5bubba
Default low coolant sensor
Does anyone know if in fact the low coolant sensor for a '99 does not come with a new coolant tank? I was told that to replace the sensor, I would have to purchase a new tank. I just had the tank painted! :cry
Old Apr 10, 2003 | 02:36 AM
SushiDave's Avatar
SushiDave
Default Re: low coolant sensor (c5bubba)
Have you tried to clean sensor? Grim build up on sensor bulb can cause problems.
Also check your wiring connections.
Good luck
Old Apr 10, 2003 | 02:35 PM
AnteVenom's Avatar
AnteVenom
Cruise-In IV Veteran
Daytona Jam 1 Veteran
I had my sensor replaced at my dealer last year and did not include tank.
Sensor is under bottom of tank and hard to get at but it was throwing a code when full so the dealer replaced the sensor only.
Old Apr 10, 2003 | 03:50 PM
6SPD98's Avatar
6SPD98
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18- '19
I'm not sure if this will help or not....my "low coolant" on the DIC came on in my car (98 coupe) I thought I had plenty of coolant in the tank. Apparently not. I added more till the entire tank was almost full. I did leave a little room at the top for expansion. No problem since then.
To low coolant sensor
