I had my tyre guy throw away the runflats and replaced them with Yokahama's but the pressure keeps dropping in two of the tyres, they changed over the sensors but are there seals or anything that may need replacing ???i can't see any nails or anything---
Sensors are sealed to rim with O-rings :yesnod: When replacing sensors you should also replace O-rings.
Also check torque on valve stem lock down nut :yesnod:
I bet if you tighten valve stem lock down nut your leak will fixed :cheers:
Yes, the little rubber O rings called washers (PT# 10268438) by the dealer should be replaced. They fit over the sensor before fitted to the wheel and the nut fits on the top side of the wheels.
