Lunati 382 Stroker
Old Apr 17, 2003 | 04:09 PM
Mehfoud's Avatar
Mehfoud
Default Lunati 382 Stroker
Has anybody installed one of these on their C5's? A couple of vendors sell the kit, wondering why not many forum members have it installed
thanks
Old Apr 17, 2003 | 05:17 PM
Mitch C's Avatar
Mitch C
Default Re: Lunati 382 Stroker (Mehfoud)
The reason why most forum members don't install the Lunati Stoker Kit is. $$ $$$$$$$$$$$$$$$$$$$$$$$.
Old Apr 17, 2003 | 05:22 PM
SideStep's Avatar
SideStep
vstella is almost finished with his 382 stroker... Do a search for post created by him...
good luck
:cheers:
Old Apr 17, 2003 | 06:02 PM
Trey395's Avatar
Trey395
Default Re: Lunati 382 Stroker (Buckmaster)
I've wondered, what is the sound difference between the stroker kits and the stock blocks. Is it only performance or does it give the car that big block exhaust note?
Old Apr 17, 2003 | 06:10 PM
Bink's Avatar
Bink
Cruise-In V Veteran
St. Jude Donor '09
My 436ci Stroker sounds pretty mean......and that is with the Corsa Touring exhaust :D I've wondered, what is the sound difference between the stroker kits and the stock blocks. Is it only performance or does it give the car that big block exhaust note?
Buckmaster- how many RWHP is your 436 making?? Is it a Darton block?( I remember reading posts while you were planning it but I can't remember if it was a darton) :cool: :cool:
Joel
Old Apr 17, 2003 | 06:11 PM
Trey395's Avatar
Trey395
Buckmaster -You don't happen to have any sound clips, do you?
Old Apr 17, 2003 | 06:20 PM
intel55's Avatar
intel55
did it a few years ago when they first came out with the kit. Very much worth then. Now, I would just get a resleeve block and make something over 400 cid.
Old Apr 17, 2003 | 06:34 PM
Mehfoud's Avatar
Mehfoud
Default Re: Lunati 382 Stroker (intel55)
Did you install the kit yourself or have a performance show do it for ya? Trying to decide between a 382 stroker and S/C package.
Old Apr 17, 2003 | 07:12 PM
intel55's Avatar
intel55
myself and a friend, who races vettes about evrey weekend.
Fairly easy. the only problem we had was getting the engine out. We were not well prepared for getting the engine out from the bottom, but we learned (cracked a lil bit of the firewall in the process :D :eek: ).
Right now I am on my 441 cid. ARE is doing the resleeve.
You could just do the resleeve, keep the stock crank, make her a screamer and then later put in a stroker crank, etc.....
overall, the 383 worked great....stump puller for sure. :cheers:
Old Apr 17, 2003 | 08:13 PM
Chris@SD's Avatar
Chris@SD
The Lunati 382 kit is a very nice kit and will come ballanced and ready to go. You will pick up some great HP from the install of the kit as well as gain a lot in parts strength and integrity. While you have the engine out, you can check all the clearances and put the block back together in meticulous working order.
The change in sound you get is going to come from compression changes and camshaft selection. The more overlap, the louder the exhaust will be.
Good luck and let me know if you need any help with the kit or complete engine or even just some questions...
To Lunati 382 Stroker
