pop-up headlight problem....help
Old Apr 17, 2003 | 09:05 PM
C6 DVL's Avatar
C6 DVL
St. Jude Donor '08
Default pop-up headlight problem....help
today I turn on my parking light, and the lights pop-up, but the headlights lights are off, one more click up and the lights turn on. I turn lights off the head lights go down but the passanger side motor is still running w/a ratcheting noise for about 10 seconds. :cry
problem #1, lights pop-up in the parking light position
problem #2, right side motor makes a ratcheting noise, thinking its not in the down position.
help please :skep: :skep:
[Modified by c5edko, 9:06 PM 4/17/2003]
Old Apr 17, 2003 | 09:27 PM
16Again's Avatar
16Again
St. Jude Donor '07-'12, '20
Default Re: pop-up headlight problem....help (c5edko)
Time for a new headlight motor. Call your dealer and get a price. Been there done that. Fortunately mine was covered under warranty.
Bob
Old Apr 18, 2003 | 04:06 AM
Blackjetvette97's Avatar
Blackjetvette97
Default Re: pop-up headlight problem....help (16Again)
Hi all,
c5edko, what year is your Vette? The '97's and '98's have a headlamp actuator motor you can open up to get at the nylon gear wheel inside(which is what is stripped) and replace it. It's a piece of cake. I had to do it and luckily found a replacement part from a junk yard. The '99's and up have a sealed motor, so you're screwed if you have this year up. HTH
Steve
Old Apr 18, 2003 | 10:49 AM
C6 DVL's Avatar
C6 DVL
St. Jude Donor '08
Default Re: pop-up headlight problem....help (Blackjetvette97)
ITS A 2002
Old Apr 19, 2003 | 01:49 AM
bigsmatty's Avatar
bigsmatty
mine pops up on the left side every once in as while, some times it just stays down. is my motor going out or is it just stuck?????
Old Apr 19, 2003 | 06:50 PM
EWill3rd's Avatar
EWill3rd
Default Re: pop-up headlight problem....help (bigsmatty)
if one of the motors is bad it will act like yours.
You just have to replace the faulty motor and all will return to normal.
The failing motor causes the headlamp module to raise them both in the park lamp position.
Just replace the faulty motor.
EWill
To pop-up headlight problem....help
