Yep finally it happend to me. The column lock is stuck so the wheel turns freely and when you go to drive the car it will turn off after about 2 feet. Will a CLB fix this or do I have to get the CLB and new lock??
Re: OH JOY COLUMN LOCK STUCK IN OFF POSTION!!! (DCBStingray)
It may not be the column lock. It may be theft prevention system. Pull the key out of the ignition a couple of times and then give it a try. If that does not work, look on the sides of the key for what looks like a piece of small wire(both sides). Clean those small wires with contact cleaner or rubbing alcohol. Give it a try again. If this does not work,you may have to pull one of the battery cables for a few seconds and reinstall the cable. Hope this helps
Alittle more info about this I should have said earlier. I had the battery unhooked for about 2 weeks, I was doing a cam install and ended up waiting for the cam longer than I expected.
Ok I just tried the spare key and cleaned the other ket w/ rubbing alchol still getting the SCL message. What I can't understand is that it is not locked and when the pull key message comes on I can hear some clicking in the passernger side fuse box. :confused: :confused:
When you remove the key, can you hear the column lock? If not, do you know where the fuse box is in the passenger footwell. If so, pull fuse 25, I think and put back and give it a try. I will check tha fuse number and get back soon!!!!!!!!! You need to get the CL bypass.
