burning oil
Old Apr 21, 2003 | 10:26 PM
johnsct's Avatar
johnsct
Cruising
Default burning oil
My 01 AT coupe is burning about 2 quarts of oil per 5000 miles after 15k miles. My dealer tells me this is normal. I change oil each 5k miles and drive fast but don't race. What should I expect the oil consumption to be?
Old Apr 21, 2003 | 10:43 PM
Default Re: burning oil (johnsct)
Before I had the rings replaced in my 2000, it was burning a quart every 1200 miles. Many on the forum have had much worse consumption rates. At the time I had mine fixed (November 2001), the GM standard for excessive oil consumption was more than 1 quart every 2000 miles. While the car should not burn a quart as quickly as 2500 miles, I doubt that GM will consider it excessive.
Old Apr 21, 2003 | 10:49 PM
Wt99C5's Avatar
Wt99C5
[Modified by Wt99C5, 3:50 AM 4/22/2003]
Old Apr 22, 2003 | 12:17 AM
1SGRET's Avatar
1SGRET
St. Jude Donor '12-'13
IMHO it shouldn't burn any but GM says 1 quart every 2000 miles is acceptable.
Old Apr 28, 2003 | 12:09 AM
johnsct's Avatar
johnsct
Cruising
Default Re: burning oil (JDs00PewterCoupe)
Thanks... any problems with the ring job? How was the oil consumption after the fix? What did you have to do to get GM to agree to the repair?
Old Apr 28, 2003 | 12:51 AM
CAPN17's Avatar
CAPN17
I did not realize the LS6 was a 2 cycle engine. That is an unacceptable oil consumption rate and you should push the General to correct it. Just MHO
Old Apr 28, 2003 | 07:30 AM
vettenuts's Avatar
vettenuts
Default Re: burning oil (CAPN17)
I know I will get some hate mail for this, but I have been corresponding with someone on another board who switched from Mobil-1 to Amsoil and had a noticable improvement in oil consumption going from 1-1/2 quarts every 3,000 miles to 1/4 quart in 5,000 miles. The Noack number for Mobil-1 is pretty high and may play into this problem to some degree.
If it were me, before I let the dealer pull the motor apart, I think I would try a different oil and watch for an improvement. At least it's worth a shot.
OK, where did I put that flame suit :lol:
[Modified by vettenuts, 7:31 AM 4/28/2003]
Old Apr 28, 2003 | 10:47 AM
Mopar Jimmy's Avatar
Mopar Jimmy
From: Elmhurst, IL (West Suburb of Chicago) & Home of MEGA Horsepower
St. Jude Donor '06
Default Re: burning oil (vettenuts)
IF your a manual tranny and do alot of slow city driving uder high rpms and light load in 2nd gear try driving around in 3rd or 4th gear under less rpms as the General says that should improve oil consumption.
Goodluck
Old Apr 28, 2003 | 10:57 AM
bierbelly's Avatar
bierbelly
:_dupe: :skep: :rolleyes:
To burning oil
