Carbonization????
Old Apr 22, 2003 | 11:49 AM
Tony B's Avatar
Tony B
Default Carbonization????
Help...what does it mean?? I saw a post on here..can anyone explain it in KISS (Keep It Simple Stupid) terms....thanks. :yesnod:
Old Apr 22, 2003 | 11:57 AM
User 81424's Avatar
User 81424
Default Re: Carbonization???? (Tony B)
It means the inside of your combustion chamber getting carbon on the surface of the pistons, valves, and spark plug from burning oil. Even though I did the PCV mod, I run my hard, with good gas, so carbonization was not a problem for me. I just wanted to keep my chambers as clean as possible.
Old Apr 22, 2003 | 12:12 PM
Tony B's Avatar
Tony B
Default Re: Carbonization???? (CPT Z06)
CPT Z06
I used to be stationed in Wiesbaden...stationed in OK now. MAJ in the Army...2 questions what is the PCV mod and how do you reduce or eliminate carbon???
Old Apr 22, 2003 | 12:53 PM
RskyBns's Avatar
RskyBns
If you already have excessive carbon-buildup....you can try this procedure from the tech tips section.
https://www.corvetteforum.com/techti...=212&TopicID=1
:cheers:
Old Apr 22, 2003 | 01:01 PM
Tony B's Avatar
Tony B
Default Re: Carbonization???? (RskyBns)
Good info...how can you tell if you have excessive carbon build-up??
What are the symptoms??? :crazy:
Old Apr 22, 2003 | 01:32 PM
RskyBns's Avatar
RskyBns
Pinging and oil consumption are a couple.
Old Apr 23, 2003 | 01:34 AM
User 81424's Avatar
User 81424
Sir, do a search for the PCV mod you will get lots of hits and many pics. Basically you are putting a small oil/water separation air filter inbetween the PCV and the throttle body to trap the oil fumes that normally get burned and coat the inside of your intake runners.
Go to SEARCH upper left, type PCV, and choose C5 Tech/Performance section.
To Carbonization????
