Dual Climate control Knobs - how do you get them off?
Old Apr 22, 2003 | 09:44 PM
Z28Z28's Avatar
Z28Z28
Default Dual Climate control ***** - how do you get them off?
I scratched my passenger side **** and want to replace it - tried to pull it off, but does not seem to want to come off? Should I pull harder or??? :confused:
Old Apr 24, 2003 | 10:20 PM
Z28Z28's Avatar
Z28Z28
Default Re: Dual Climate control ***** - how do you get them off? (Z28Z28)
still looking for some help ...
Old Apr 25, 2003 | 10:52 AM
gonbad's Avatar
gonbad
I don't think they are designed to be removed. This is not a normal item to be taking apart. You DO NOT want to break it. A new one is like $600! :eek:
Old Apr 25, 2003 | 11:10 AM
Kenny94945's Avatar
Kenny94945
I do not have an answer either.
The A/C module is not to thick and I also think it was designed not to be taken apart...just replaced.
If you are going to try to repair something in it...make the leap and pull the center council and remove the unit.
If removed you can get leverage behind the ***** and not damage any other interior piece.
Else, not sure why you need the ***** removed.
Old Apr 25, 2003 | 11:19 AM
Z28Z28's Avatar
Z28Z28
Default Re: Dual Climate control ***** - how do you get them off? (Kenny94945)
radio ***** pull off - my climate **** is scratched and I wanted to replace it .... does anyone know for sure if **** is permanent - those of you with the parts cd, can you look it up and see if you can find a replacement #? thanks
Old Apr 25, 2003 | 11:33 AM
Kenny94945's Avatar
Kenny94945
Hello,
Still unsure if they are replacable...the book comments that they are part of # 5 (which is the unit).
**** driver - 16226541
**** passe- 16226543
Old Apr 25, 2003 | 12:53 PM
FL1BY's Avatar
FL1BY
Cruise-In IV Veteran
just detailed my interior.. a good pull did it. if your replacing it a sturdy set of plires works too! :banghead:
Old Aug 3, 2017 | 08:49 PM
Pile of cash's Avatar
Pile of cash
1st Gear
Default climate control *****
I need a drivers side climate control **** and they are discontinued. Any idea how I may find one?
Old Aug 5, 2017 | 08:53 AM
StrangelovesM6Vert's Avatar
StrangelovesM6Vert
I bought these C6 *****
The factory C5 ***** are so bland and cheap looking.
The paint on my old billet C5 ***** needed redoing and these were only 20.00
You get 4 *****
http://www.ebay.com/itm/400607341282...%3AMEBIDX%3AIT
2 of them have tiny allen screws and a plastic bushing that has to be drilled out to 11/64" by holding a drill bit in a pair of vice grips and turning it by hand to whittle out the plastic.
Then push them on and tighten the allen screws with the supplied allen key.
You can get them in chrome and/or gunmetal and/or Corvette logos
To Dual Climate control Knobs - how do you get them off?
