Help!!!!
Old Apr 25, 2003 | 09:11 PM
ITSovr4U's Avatar
ITSovr4U
Default Help!!!!
Went to track today ran my car way to many times. Now I have a weird noise coming from the back of car. It kind of sounds like a whinning noise that is present only on acceleration and disappears when I let off the gas. The noise is most present at low RPM in 5 os 6th gear on highway. It also goes away when clutch is in. When I say it is present only on acceleration I mean as long as foot is on the gas even just barely. I know it is hard diagnose something without actually driving it but any suggestion as to what it could be would be greatly appreciated. I did run my new best of 11.67 and just want to know how much it cost me to do so. :rolleyes: Thanks,
JOHN :seeya
Old Apr 25, 2003 | 09:57 PM
Kenny94945's Avatar
Kenny94945
Default Re: Help!!!! (ITSovr4U)
Well lets hope it is not your differential gears. But..that is my guess.
So the noise is present with acceleration.
So the car is squatting in the rear?
Well jack er up. Spin the wheels. Perhaps a speed sensor gear near the wheel. Loose tie rod. Bad u-joint on the out put shafts. Cable hitting something.
Jack er up and start her up.
You could check the diff oil level and then drain the diff oil and look for metal shavings also.
Old Apr 25, 2003 | 10:36 PM
ITSovr4U's Avatar
ITSovr4U
Default Re: Help!!!! (Kenny94945)
Thanks, Any other opinions :seeya
Old Apr 25, 2003 | 10:41 PM
Redline Motorsports's Avatar
Redline Motorsports
Bring it by tomorrow... You don't think the 40 passes you made at the track might have anything to do with it :lol:
Old Apr 25, 2003 | 10:48 PM
ITSovr4U's Avatar
ITSovr4U
Default Re: Help!!!! (9D9LS1)
It was 0nly 24, lets not get carried away. :lolg: :lolg:
Old Apr 26, 2003 | 03:47 AM
ITSovr4U's Avatar
ITSovr4U
ttt :)
Old Apr 26, 2003 | 07:38 PM
ITSovr4U's Avatar
ITSovr4U
ttt :seeya
Old Apr 26, 2003 | 08:09 PM
TCW's Avatar
TCW
St. Jude Donor '06-13,'16-'17, '19
Since it only happens under load, I'd say you have a bad carrier bearing in the diff.
Tom
Old Apr 27, 2003 | 03:05 AM
ITSovr4U's Avatar
ITSovr4U
Default Re: Help!!!! (TCW)
ttt :seeya
To Help!!!!
