Anyone with a 1999 service manual, Please Help!
Anyone ever seen anything like this? I'm beginning to think that it's a stuck relay in the BCM. If I pull the BCM #2 - IPC fuse (if I remember right), the IPC lights go out. Problem is, I have to keep taking out the fuse when I shut the car off. I can't leave it out as the car will not start without it.
What I'd like to do is pop open the BCM and look for any corrosion or a stuck relay. I know from reading posts here that other BCM's have had water intrusion (AC) problems and this was previously a Florida car. I'm an elec engineer type so jumping into the BCM isn't necessarily an issue for me.
What I'd really like to find out is a wiring list to the BCM if anyone has one available. Preferably anything making reference to IPC lighting.
Any help would be greatly appreciated.
There are so many things involved in the IPC that you really need a scan tool to diagnose what is going on.
E-mail me at paulpegg@optonline.net since I was just browsing here and noticed your message. I don't have the time to come here regularly.
Paul
