QUICK HELP! Car on jacks....CAGS defeat not fitting?
Hey guys...I know this topic has been posted many times...but I recently ordered the CAGS defeat from a forum vendor....
I took my front right wheel off, and am pretty sure I found where to put the CAGS....
If you are facing the front wheel, you look and it is attached to the metal via a small plastic clip.
It is blue and white...which is what it states in the directions...it is the only blue and white connector I see, however, it seems to run to the front wheel...
Anyway...the CAGS defeat I got does NOT connect to this blue/white setup...
I have a '03 Z06 if that helps...
What I noticed, is the CAGS defeat is a circle...while the blue/white is not a ful circle (if you get what i mean...the pieces do not fit, because the circle will not fit in the hole smaller than the circle)
Any help would be appreciated...my car is apart and its late!
