Check Engine Light>>>>HELP
Old Apr 30, 2003 | 02:14 PM
Ben01C5's Avatar
Ben01C5
Default Check Engine Light>>>>HELP
Well I was going to the beach for lunch, and I look down and see the check engine light is on. I just went out of warranty too.
Any idea what this light could be for? 90% of the miles I have put on are highway, and the car is running just fine.
Old Apr 30, 2003 | 05:11 PM
Elk's Avatar
Elk
Default Re: Check Engine Light>>>>HELP (Ben01C5)
If the light is not flashing, it's likely emissions related. For example, the check valve on the air system, passenger side, often fails and this is a cheap repair.
Pull the code off of the DIC and post the code number as somebody will know what it means. To get the code, hold down the options button and hit the fuel button four times. The display will run through and display all codes that have been stored. Write them down. To get out of diagnostics mode, hit the E/M button.
Old Apr 30, 2003 | 07:28 PM
C3 RV's Avatar
C3 RV
St. Jude Donor '15
The same light came on in my Avalanche yesterday, at 44K. After some reading online and the owners manual, I retightened the gas cap. After five trips, the light turned off. Sometimes, it's just that simple.
Old Apr 30, 2003 | 07:31 PM
Ben01C5's Avatar
Ben01C5
Default Re: Check Engine Light>>>>HELP (Elk)
I called the dealer to make an appointment, and they told me to check the gas cap and call them back in a couple days if the light doesn't go off.
I will run through the codes stored in the DIC and see what is in there. I never knew it was that easy.
Do I need the car running or just in the Accesories on position?
[Modified by Ben01C5, 12:43 AM 5/1/2003]
Old Apr 30, 2003 | 09:00 PM
quickie350's Avatar
quickie350
:iagree: :iagree: :iagree: :iagree: :iagree: :iagree:
To Check Engine Light>>>>HELP
