Questions for Hypertech owners
Old May 10, 2003 | 09:42 AM
i_york's Avatar
i_york
Default Questions for Hypertech owners
Guys/gals,
1. Is there a proven benefit (in ET and 0-60) in changing shift points?
2. I have the 3.15 factory performance gear... do I need to tell the Hypertech I have a 3.15 gear, or can I just leave it as stock (by pressing 'N' at the rear axle prompt).
3. When I want to modify shift-points or firmness, it would seem that the Hypertech re-flashes the PCM with EVERYTHING (including the fuel/ignition map). My gripe with this, is that any 'learning' the PCM has done since the last flash will be lost. Am I correct in saying that the fuel/ignition map is re-loaded even if you only want to change shift points, etc?
4. How long (miles) does it generally take for the PCM to adapt to a new fuel/ignition map? I have some spark knock with the Hypertech map (even the RFG version), but I'm hoping the PCM will adapt from knock sensor input and retard the timing only as far as necessary so as to stop the spark knock.
5. Say you just want to remind yourself of what settings you have programmed-in... you plug the Hypertech in and take a look. Do you now HAVE to re-program again, or can you just turn the ignition off and disconnect the Hypertech at any point and be OK?
Thanks a lot guys... the Hypertech manual leaves these questions unanswered.
[Modified by i_york, 2:45 PM 5/10/2003]
Old May 10, 2003 | 11:54 AM
jawsski's Avatar
jawsski
Default Re: Questions for Hypertech owners (i_york)
1. slight improvement
2. No
3. yes everything is reloaded
4. don't know
5. Don't disconnect at any point
6. Read Directions and follow them
Old May 10, 2003 | 11:48 PM
lost's Avatar
lost
Default Re: Questions for Hypertech owners (jawsski)
Any time you hook up the programmer, if you don't choose to go back to stock, you will have to go thru the programming procedure even if no changes are made.
Old May 11, 2003 | 10:40 PM
CCrane65's Avatar
CCrane65
In response to number 3, it takes the same amount of time even if you don't load the engine management but it does not load the engine management unless you tell it to.
In response to number 5, when you plug the HPP III in it goes through and tells you what modifications were previously made. At this point, no changes are pending and you can turn off the key and disconnect the HPP III. You do not have to go through the 15-20 minutes just because you hooked up the HPP III.
In response to number 4, I have read elsewhere in here that it takes about 100 miles for the PCM to adjust to changes in Air/Fuel etc.
Sorry, I hate typos.
I mean I really hate typos.
[Modified by CCrane00, 9:42 PM 5/11/2003]
[Modified by CCrane00, 9:43 PM 5/11/2003]
[Modified by CCrane00, 9:44 PM 5/11/2003]
Old May 12, 2003 | 02:27 PM
Cajun @ Edgyvette's Avatar
0Cajun @ Edgyvette
Former Vendor
St. Jude Donor '07-'08-'09-'10-'11-'12'-'13-'14-'15
Default Re: Questions for Hypertech owners (CCrane00)
Hello to everyone. I have a question........What are the stock shift points (RPM) on my MY2000 A4? I have the shift points set at +3, +6, +9. What do I set the rev limiter at (6200?-6300?). I have been told that I risk floating the valves at anything higher than this? Any input would be appreciated. Thanks
To Questions for Hypertech owners
