AGM Battery ?
Old May 11, 2003 | 02:55 AM
jm's Avatar
jm
Default AGM Battery ?
Absorbent Glass Matt battery. How can you tell if
you have one ?
I just had the battery replaced on my '01, Bad Cell.
It had caused a lot of problems and 3 visits to the
dealer before fix. I don't know what was replaced,
the new one is a Delco, Model 75P-7YR Platnium Pro.
Scary article in the new (Jul) CF Mag. (corrosive correction)
My HVAC switch and line also had to be replaced,
Air direction would not control. I had no corrosion issues though.
According to CF the AGM Battery went in '01. Can't tell ?
JM
Old May 11, 2003 | 03:31 AM
bowtiebandit's Avatar
bowtiebandit
Default Re: AGM Battery ? (jm)
http://www.acdelco.com/html/catalog/index_auto.htm
75P7YR BATTERY, ABSORBENT GLASS MAT
[Modified by bowtiebandit, 3:33 AM 5/11/2003]
Old May 11, 2003 | 04:01 AM
Dave68's Avatar
Dave68
My OEM AGM battery looks like this:
You should see "AGM" labeled on the battery.
Old May 11, 2003 | 05:04 AM
jm's Avatar
jm
Default Re: AGM Battery ? (bowtiebandit)
Thanx,
The 75P nomenclature and 'Professional Platinum' brand
equal AGM
JM
Old May 11, 2003 | 05:13 AM
jm's Avatar
jm
Default Re: AGM Battery ? (Dave68)
No AGM Label like yours, but I see the Model #75P
on mine
Old May 11, 2003 | 08:49 AM
Oldvetter's Avatar
Oldvetter
Look or feel the end of your battery case. If it has two rounded parts instead of a straight case, it is an AGM battery.
This will work on any manufacturer's AGM battery.
Old May 11, 2003 | 09:29 AM
Monk's Avatar
Monk
Default Re: AGM Battery ? (Oldvetter)
Please help me to understand... I have a 1998 C5 and the original battery that came with the car (which I understand was subject to leakage at the battery posts) was replaced right before I bought the car with a new, el-cheapo, non-AGM aftermarket battery.
Do I have a ticking time bomb here? Do I need to switch to an AGM battery right away? In other words... was the problem just with the defective Delco battery leaking... or is it a problem generic to all conventional batteries installed within a C5 such that I really need to switch to an AGM right away to protect the electronics??? Thanks!
Monk :flag :flag :flag
Old May 11, 2003 | 10:18 AM
bowtiebandit
Default Re: AGM Battery ? (Monk)
No..this problem was not a C5 issue only, it crosses all makes and models with GM. Last I heard from engineering was that 2 things had caused it, 1..battery cable bolts where crossthreaded from the factory and 2..bolts where not torqued enough,not overtorqued. Seems that when either happens over the life of the car to much resistance is built up at the connection, thusly overheating said connection and causing the case to warp ever so slightly around the terminal and causing the leak. There is alot of conjecture about the root cause but either way asl ong as the cables are tight and do not allready have acid contamination you should be fine.
Old May 11, 2003 | 10:32 AM
Monk's Avatar
Monk
Okay... thanks!
I'd hate to throw away a perfectly good 15 month old battery just for the sake of going AGM. It is not a Delco battery. I believe the seller said he bought it at Sam's club. Hope it wasn't made by Delco and marketed by others!!! No leakage so far and no issues with cable tightness.
Old May 11, 2003 | 12:20 PM
Richin Chicago's Avatar
Richin Chicago
Okay... thanks!
If it is Sam's it is Champion. It's the same one I bought. It has much more structure around the terminals.
Old May 11, 2003 | 08:17 PM
jm's Avatar
jm
Thanx for the Resp
End. . . which end ?
2 rounded parts where ?
Top of case looking down :
Front , back, or side edges ?
Or do you mean the vertical side corners are rounded ?
I checked the Delco Site (www.acdelco.com)
under Parts info. The only model number that
matches AGM is .... 75P. My battery Has 75P- 7Yr.
typed under the AC Delco Professional Platinum label.
Seems odd they would't say AGM on the repacement.
like theOEM photo from Dave 68 ?
PS,
I found a lot of good info in the archives
Thanx again
JM
Old May 11, 2003 | 08:57 PM
JWD01's Avatar
JWD01
My AGM has all the correct numbers, looks exactly like the picture, but doesn't say AGM anywhere on the battery. :cheers:
Old May 11, 2003 | 09:23 PM
jm's Avatar
jm
Default Re: AGM Battery ? (JWD01)
JWD,
Correct numbers= AC Delco 75P-7YR ?
Thanx
JM
Old May 11, 2003 | 09:34 PM
Power Shifter's Avatar
Power Shifter
I just got a new 75P/7year also. Mine dosen't say AGM anywhere either, and the CCA is 550, 270 load amp. Ric
Old May 11, 2003 | 10:52 PM
JWD01's Avatar
JWD01
JWD,
Thanx
JM
:yesnod:
Old May 12, 2003 | 04:28 PM
Dave68's Avatar
Dave68
Take a look at:
and enter the requested info for a 2001 or newer Corvette. When the list of available batteries appears, you will notice that the "P" does indicate that the battery is an AGM.
[Modified by Dave68, 1:29 PM 5/12/2003]
Old May 12, 2003 | 04:31 PM
4DCYKEY's Avatar
4DCYKEY
Default Re: AGM Battery ? (Power Shifter)
Just got my new AGM last week. Old battery was close to 4 years old (no problems), and I was afraid of leakage. :chevy
[Modified by 4DCYKEY, 11:52 AM 5/13/2003]
To AGM Battery ?
