p0332 rear knock sensor code
Old May 11, 2003 | 12:37 PM
bigsteff's Avatar
bigsteff
Default p0332 rear knock sensor code
I get the rear knock sensor code (p0332h) on my 99'. When it happening, the car continues to run normally without any noticable indication of a problem. I have reset the code several times and now plan to take the car in for service.
Anyone had this problem? If so, how was it resolved?
Old May 11, 2003 | 01:29 PM
bowtiebandit's Avatar
bowtiebandit
Default Re: p0332 rear knock sensor code (bigsteff)
You may be experiencing this..
Audible Spark Knock (Detonation), MIL Illuminated, DTC P0332 Set (Replace Rear Bank Knock Sensor and RTV Area Around Sensor) #02-06-04-023A - (06/14/2002)
1998-2002 Chevrolet Camaro, Corvette
1998-2002 Pontiac Firebird
with 5.7L Engine (VIN G -- RPO LS1)
1999-2002 Chevrolet Silverado, Suburban, Tahoe
2002 Chevrolet Avalance
1999-2002 GMC Sierra, Yukon, Yukon XL
2002 Cadillac Escalade, Escalade EXT
with 4.8L, 5.3L or 6.0L Engine (VINs V, T, Z, N, U -- RPOs LR4, LM7, L59, LQ9, LQ4)
This bulletin is being revised to add Cadillac Escalade and Cadillac Escalade EXT to the Models. Please discard Corporate Bulletin Number 02-06-04-023 (Section 6 -- Engine/Propulsion System).
Condition
Some customers may comment on a mild to severe engine ping (commonly referred to as spark knock), usually worse during acceleration and/or an illuminated MIL. Upon investigation, the technician may find DTC P0332 set.
Cause
This condition may be the result of corrosion of the rear bank knock sensor due to water intrusion into the sensor cavity. This condition is more apparent on vehicles in which customers frequently wash the engine compartment.
Correction
Replace the rear bank knock sensor and build a dam (wall) around the sensor using RTV to divert water away from the sensor
Old May 11, 2003 | 02:09 PM
SpinMonster's Avatar
SpinMonster
Default Re: p0332 rear knock sensor code (bowtiebandit)
you got to be a member to find out these things :flag
To p0332 rear knock sensor code
