AIR hose?
Old May 12, 2003 | 08:38 AM
i_york's Avatar
i_york
Default AIR hose?
Gonna install my K&N cone filter within the next day or so, but there won't be anywhere to attach the AIR hose that currently plugs into the side of the stock airbox.
What does the AIR hose do? Will there be any problems with just disconnecting it? Should I plug it?
[Modified by i_york, 1:39 PM 5/12/2003]
Old May 12, 2003 | 09:28 AM
CP's Avatar
CP
Default Re: AIR hose? (i_york)
It's just the intake for the AIR pump.
Old May 12, 2003 | 11:02 AM
i_york's Avatar
i_york
Default Re: AIR hose? (CP)
Do you mean the AC compressor? Do I need to put a filter on it if I leave it disconnected?
Old May 12, 2003 | 12:28 PM
1SlowC5's Avatar
1SlowC5
You just need the little K+N Filter that the hose fits over, then you just tie it up. Any of the vendors will have it. :cheers:
Old May 13, 2003 | 03:39 AM
i_york's Avatar
i_york
Default Re: AIR hose? (1SlowC5)
Thanks for the replies guys, but what, exactly, does this hose feed?
For the moment, I've left it disconnected and unfiltered (but I've taken the elbow piece of the old airbox and connected it to the free end of the AIR hose to prevent any possibility of water ingress).
Whilst driving to work this morning, I could detect a strong smell of K&N filter oil wafting into the cabin! :U
[Modified by i_york, 8:40 AM 5/13/2003]
Old May 13, 2003 | 07:56 AM
ToplessTexan's Avatar
ToplessTexan
Cruise-In II Veteran
As CP said, it's for the AIR pump (Air Injection Reactor.) The pump feeds fresh air into the exhaust manifold under direction of some relays and solenoids controlled by the PCM.
To AIR hose?
