Need new UD pulley....
Old May 12, 2003 | 02:47 PM
Phil97SVT's Avatar
Phil97SVT
Default Need new UD pulley....
Any suggestions? I think I might try another ASP.
Phillip
Old May 12, 2003 | 04:33 PM
Bink's Avatar
Bink
Cruise-In V Veteran
St. Jude Donor '09
Default Re: Need new UD pulley.... (Phil97SVT)
Phillip - I went with the ATI, but it's only 10% reduction. NEVRENUF said he damaged his crank snout when his ASP let go. JMHO. ;) :cheers:
Old May 12, 2003 | 04:46 PM
C5-VERT's Avatar
C5-VERT
Cruise-In IV Veteran
Default Re: Need new UD pulley.... (binksZ06)
:withstupid: And it wasn't pretty either! :U
Old May 12, 2003 | 04:47 PM
Phil97SVT's Avatar
Phil97SVT
Well the ASP isnt available for the next month or so. The ATI might be the only route to go. How much of a weight differential?
Phillip
Old May 12, 2003 | 06:35 PM
Phil97SVT's Avatar
Phil97SVT
Email from Dave Farmer *************
ATI is the only real choice, imho. I run the full aluminum setup, 10%
underdrive. It is less than 1/2 the weight of OEM, and of course, 10%
underdrive.
GM Racing was involved in helping ATI pick the proper "rubbers" for the
unit, so I know they know what they are doing.
Dave
Old May 12, 2003 | 06:55 PM
Bink's Avatar
Bink
Cruise-In V Veteran
St. Jude Donor '09
So with GM picking the "Rubbers" we should be safe! :lolg: Sorry, couldn't help myself. :D :cheers:
Old May 12, 2003 | 07:53 PM
howardl's Avatar
howardl
Where do you get the ATI full alluminum pulley??? :confused:
Old May 12, 2003 | 08:31 PM
Bink's Avatar
Bink
Cruise-In V Veteran
St. Jude Donor '09
Default Re: Need new UD pulley.... (howardl)
Here you go http://www.atiperformanceproducts.co...ts/damserp.htm :cheers:
Old May 12, 2003 | 09:30 PM
Phil97SVT's Avatar
Phil97SVT
ATI sells an aluminum pulley. It includes an aluminum hub where the standard one has a steel hub. The aluminum hub needs a new seal to work correctly.
Phillip
Old May 13, 2003 | 12:01 AM
bparker's Avatar
bparker
Hey Binks - if the ATI is 10% what is the ASP UD ??%?
Old May 13, 2003 | 10:10 AM
Phil97SVT's Avatar
Phil97SVT
Default Re: Need new UD pulley.... (bparker)
ASP is 25% UD. Many have said that harmonics will kill HP faster than rotating weight.
Phillip
Old May 13, 2003 | 12:12 PM
bparker's Avatar
bparker
So what you are saying is the ATI has less harmonics? Even though it has less underdrive @ 10%? This will produce the same HP (in effect) as the ASP @ 25% UD?
Over,
Old May 13, 2003 | 12:24 PM
Phil97SVT's Avatar
Phil97SVT
Over,
The ATI is a damper as well as an underdrive pulley. The ATI rep said that it dampens the torsional virbations which cause the crank to flex making timing more accurate to cylinder pistion. You really need to talk to someone at ATI, the pulley really seems to be the hot lick but it comes at a cost. Why do all of the ASA teams run this damper vs just an inexpensive ASP. Also ATI has contigency cash for regional and national races. You wont be able to pass tech at a big race with an ASP nor will you be able to win any extra contingency cash. :seeya:
Phillip
Old May 13, 2003 | 12:30 PM
bparker's Avatar
bparker
Wow - goog things to know.. :seeya
Old May 13, 2003 | 12:37 PM
Phil97SVT's Avatar
Phil97SVT
The thing that had me puzzled was the ATI rep said that the Crank can flex as much as 8 degrees at high RPM from the combustion stroke. The ATI damper is supposed to eliminate this. All the big nascar teams run them.
Phillip
Old May 13, 2003 | 12:42 PM
bparker's Avatar
bparker
8 degrees is alot man :eek: - I wonder if he meant on a 200K mile motor :jester
Old May 13, 2003 | 12:44 PM
Phil97SVT's Avatar
Phil97SVT
LOL, he was talking about a normal 500hp ASA/nascar motor.
Phillip
To Need new UD pulley....
Old May 13, 2003 | 06:09 PM
johnnyC5's Avatar
johnnyC5
Phillip
what happened to your "other" pulley? (i'm assuming u had another one, right?)
Old May 13, 2003 | 06:12 PM
Phil97SVT's Avatar
Phil97SVT
Default Re: Need new UD pulley.... (johnnyC5)
I think someone stole it out of my garage.
Phillip
Old May 13, 2003 | 06:18 PM
Bink's Avatar
Bink
Cruise-In V Veteran
St. Jude Donor '09
Over,
Phillip
And the ASA teams run the LS1 motor ( non-stock of course)- FWIW.
