One of the sensors just quit. I believe it to still be working as it is fairly new. Anyhow the check tire sensor system warning came on and when I checked the pressure on one of the tires it said"Lxxx". First time I looked it was blank, the next time I looked, it was as above.
Is this probably just a re-learn problem since it worked before? So do they tend to do this once in a while? It is trivial, but it bothers me.
Re: Help with tire sensor, please(redundant ?) (woodhead)
I have not had this problem before. Next time it happens follow your manual procedure that stated how to calibrate your wheel sensors (magnet). Maybe someone can chime in and give you better help! :lurk:
Re: Help with tire sensor, please(redundant ?) (leadfoot4)
Ok - Now the darn thing on the same tire worked fine after my post, and this morning things were fine. I stopped somewhere for ten minutes, then started up and left, only to find it was on the blink again, same one.
