Help w/ P0113 & p1111, Headlight problems also
Old May 15, 2003 | 10:12 AM
dtpracing's Avatar
dtpracing
Default Help w/ P0113 & p1111, Headlight problems also
Hey guys,
I have a 99 coupe w/ a Halltech cold air (which has been on the car for 2 years), last week I got a check engine light, codes were p0113 and p1111, replaced the IAt sensor, cleared the codes...drove the car a couple of times w/ no check engine light. Next day the light comes back on....same codes, I extended the wiring to the sensor after talking to another forum user who had the same problem, cleared the codes...after about 2 hours (total) of driving the check engine light came back for the same codes. Any advice on what to look for next?
Next problem, replaced the headlight motors....worked fine for 2 days, now everytime the headlights close, the driver side comes back up and stays up. Any ideas?
Lat problem...Have intermittently been seeing "active handling system warming up" on CIC. After 8-10 minutes CIC says sytem warmed up and it works fine...Should I be concerned? :banghead:
