Does nitrous decarb your engine?
Old May 15, 2003 | 02:27 PM
OliverM5's Avatar
OliverM5
Active Streak: 90 Days
Default Does nitrous decarb your engine?
I run a bottle through the car every two weeks - does this effectively clean out the engine (carb buildup, etc?) :confused:
Old May 15, 2003 | 04:42 PM
benelliwang's Avatar
benelliwang
Default Re: Does nitrous decarb your engine? (OliverM5)
Interesting. TTT for yah :cheers:
Old May 15, 2003 | 11:36 PM
lost's Avatar
lost
Default Re: Does nitrous decarb your engine? (benelliwang)
No officer, the nitrous is not for racing, I only use it to clean the carbon off my pistons!!!
Old May 16, 2003 | 12:31 AM
ScreaminDemon's Avatar
ScreaminDemon
Yes, it will spit-shine all parts til they are gleaming!!!!!!!!!!!!!!!!!! It is the ultimate way to de-carbonize.....
Old May 16, 2003 | 10:53 AM
OliverM5's Avatar
OliverM5
Default Re: Does nitrous decarb your engine? (ScreaminDemon)
Are you joking or are you serious?
Old May 16, 2003 | 12:31 PM
c5chris's Avatar
c5chris
I was told that it really does decarbonize the engine. That's how the the service center know that youre running nitrous - your engine is wayy too clean. And that's when they void your warranty. :nopity
Old May 16, 2003 | 02:39 PM
OliverM5's Avatar
OliverM5
Default Re: Does nitrous decarb your engine? (c5chris)
Not if you don't have one anymore :D
Old May 16, 2003 | 03:16 PM
bparker's Avatar
bparker
I was told that it will keep things clean due to the extreme heat.. duno if its true..
Old May 16, 2003 | 07:59 PM
ScreaminDemon
Yes, I'm serious.
Old May 17, 2003 | 09:21 PM
styleracing's Avatar
styleracing
8th Gear
It all depends. I run a 10lbs bottle every month and I just changed the piston rings on my C5 and there was a ton of carbon. In order to clean the engine you have to lead out the engine. Get a hypertech programmer and run the engine lean to clean. Just becareful not to melt the engine.
Check it out! Http://www.styleracing.com
To Does nitrous decarb your engine?
