Compression limits
Old May 16, 2003 | 12:12 AM
SpinMonster's Avatar
SpinMonster
Default Compression limits
How high a compression ratio can you go to before you exceed the ability to use 93 octane fuel. I would like to hear about any variables that affect the answer. Thanks for your input.
I have seen 230/230 .575 lift cam and 11.75 CR on 93 octane.
Old May 16, 2003 | 12:26 AM
z0sense's Avatar
z0sense
Default Re: Compression limits (SpinMonster)
11.8 - 12.0 is really pushing the limit!
I am not sure if oxygenates would play a role...i.e. in "winter gases"
I am sure someone could expand!
Old May 16, 2003 | 11:05 AM
Chris@SD's Avatar
Chris@SD
This really depends on a whole mess of things. I have used 12.9:1 on a daily driver, used 93 octane gas and used all the timing I thought was right(above factory!!!). This is not I have a few 12.5:1 cars out there and know of bunches of others that have been running for long periods of time with no issues.
A couple of things to look at is the efficiency of the heads, shape of the combustion chamber, size of the cam, overlap, etc.
Just my experience...
Old May 16, 2003 | 12:46 PM
SpinMonster
Default Re: Compression limits (Chris@SpeedDemon)
I had no idea that some of those things came into play. Any ideas where i can read up on it?
Old May 16, 2003 | 02:45 PM
Bink's Avatar
Bink
Cruise-In V Veteran
St. Jude Donor '09
Here is an excellent explanation of CR and Dynamic CR http://cochise.uia.net/pkelley2/DynamicCR.html . :thumbs: :cheers:
DCR - The most important cam variable is intake valve closing point. The later the closing the lower the DCR. :cheers:
[Modified by binksZ06, 4:01 PM 5/16/2003]
Old May 16, 2003 | 03:17 PM
Phil97SVT's Avatar
Phil97SVT
Default Re: Compression limits (binksZ06)
I guess I'll jump in since I am probably the guy your talking about. My old setup was 11.75:1 but I had a big cam to bleed off some of the compression. You can run that high with a big cam just make sure you always have good gas 93-94 octane. With the valve reliefs I think my new compression is around 11.45:1 but will probably act like more since my old rings weren't sealing.
Phillip :nonod:
Old May 16, 2003 | 03:42 PM
SpinMonster
Default Re: Compression limits (Phil97SVT)
Very correct Phil, thanks for the input.
To Compression limits
