intake manifold option
Old May 16, 2003 | 10:54 PM
SpinMonster's Avatar
SpinMonster
Default intake manifold option
Anyone use or even know of anyone that has used this intake? http://www.mrnitrous.com/LS-SPYDER%20MANIFOLD.htm
Old May 16, 2003 | 10:57 PM
Mean Green's Avatar
Mean Green
CI III & IV Vote Ho
CI II, III, IV & V Vet
CI IV Bracket Champ
St. Jude Donor '03-'04
Default Re: intake manifold option (SpinMonster)
uhhhhhhh, for $3,000+ NO FREAKIN' WAY :cheers:
And don't waste your money on the LS6 Intake either on a "stock" motor setup :cheers:
Old May 17, 2003 | 01:01 AM
Bink's Avatar
Bink
Cruise-In V Veteran
St. Jude Donor '09
If you're going to spin that high(7000-9000) and spend that kind of money then go for the best- Hogan's http://www.hogansracingmanifolds.com/ Top notch, proven winners ,annually. :yesnod: :yesnod: :yesnod: :thumbs: :steering: :steering:
Old May 17, 2003 | 01:27 AM
NEPTUNEBILL's Avatar
NEPTUNEBILL
Default Re: intake manifold option (binksZ06)
:iagree: contact hogan and they will send you a brochure and a form to fill out with all your specs and intentions and they will give you an estimate of what to expect or if its practical for your needs. I have talked to several of the bigger tuners and they have not had good results from any of the metal intakes as they tend to loose low end and only perform in the higher range,
To intake manifold option
