Active Handling Problem?
Old May 17, 2003 | 04:33 PM
Pewtered99's Avatar
Pewtered99
Default Active Handling Problem?
I have a question with the active handling option. I believe my car has it because for one, the button is labeled "Active Handling" and I have the F45 and JL4 options (I think one of these is the active handling). The problem is the only messages I ever see on the DIC refer to traction control, it never says 'active handling' on or off.
Also, when I hold the button down for 5 seconds to try to enter the 'Competition Mode' all it does is display traction control on or off. Do I have a problem with my Active Handling system? I had bought the car with 13000 miles and have never seen an active handling message. I am frustrated and any suggestions would be appreciated.
[Modified by Pewtered99, 1:34 PM 5/17/2003]
Old May 17, 2003 | 04:51 PM
Stock Man's Avatar
Stock Man
2015 C5 of Year Finalist
St. Jude Donor '05-'06-'07-'08-'09-'10
Default Re: Active Handling Problem? (Pewtered99)
The button turns the Active Handling on or off. The only other time that you will see any message is if it is on and you loose it in a corner or something in that vien. That's when it will react with throtle control and brakes to correct the situation. As for Competition Mode try holding it down for 10 to 15 seconds depending on what else your doing it can take longer to engage. Also earlier C5's didn't have competition mode I think it may have started in 2001.
[Modified by edpainter, 1:52 PM 5/17/2003]
Old May 17, 2003 | 05:11 PM
Pewtered99's Avatar
Pewtered99
Default Re: Active Handling Problem? (edpainter)
Thanks for the info. Mine is a 99 but the owners manual did talk about the competition mode. However, I have tried holding the button for a long time and all kinds of different things and it doesn't seem to work so I guess maybe it doesn't have the competition mode.
Old May 17, 2003 | 07:28 PM
Richin Chicago's Avatar
Richin Chicago
All active handling systems have competition mode. You must be sitting still with the car running and hold the button down for about 15 seconds and it will shift into competition mode.
Old May 17, 2003 | 08:52 PM
vetterdstr's Avatar
vetterdstr
CA Events Coordinator
You may not have AH on your car. My 99 has it as an option and I really like it. :blueangel:
vetterdstr :cheers:
Old May 18, 2003 | 06:02 AM
EHS's Avatar
EHS
If you have a 1999 with the JL4 option, you have active handling.
To engage Competitive Driving mode, come to a complete stop, push and hold the AH button for at least seven seconds, you will see the mode come up on the DIC.
To see AH working, go to a large, wet parking lot and do some doughnuts. You'll see the indication on the DIC.
Old May 18, 2003 | 02:35 PM
Red C8 of Jax's Avatar
Red C8 of Jax
Default Re: Active Handling Problem? (EHS)
My 98 has AH and when I turn off the AH the DIC shows immediately AH is off. :smash:
Old May 19, 2003 | 12:33 PM
Stock Man's Avatar
Stock Man
Default Re: Active Handling Problem? (red-C5 of jax)
Went out yesterday and pushed AH at 30mph and immediately it turned off. I keep the button pushed for 5 to 10 seconds and Competition mode came on. I didn't have to stop to activate.
Old May 19, 2003 | 03:44 PM
pmarone's Avatar
pmarone
2001 cars have the ability to go into Comp Driving on the move. 2000 and prior do not.
Pete
Old May 19, 2003 | 11:34 PM
EHS's Avatar
EHS
Ed,
The gentleman who started this thread has a '99 -- he has to come to a complete stop. Trust me.
You, on the other hand, don't.
Enjoy. :cheers:
Old May 20, 2003 | 08:52 AM
The Yav's Avatar
The Yav
Pewerted99,
Try seeing if Active handling has triped/stored any codes in your DIC. To do this hold the OPTIONS button down, while pressing the FUEL button 4 times. Any codes begining with H is histroy code. I believe Active handling starts with 28 TCS. Before you check for codes make sure your DIC is clear of any code ie (Low fuel, door ajar, change oil now) by pressing reset.
v/r
THE YAV :chevy
To Active Handling Problem?
