Turn Signal Bulb Replacement
Old May 19, 2003 | 07:15 PM
CP's Avatar
CP
Default Turn Signal Bulb Replacement
Anyone have the link on to how to get at the bulb to change it?
Old May 19, 2003 | 07:24 PM
texasredc8's Avatar
texasredc8
Default Re: Turn Signal Bulb Replacement (CP)
Front or Rear??
Rear is fairly straightforward at unscrewing 2 bolts and removing the red lamp assembly.
Front is a little more complicated, but not too hard. If you raise the hood and raise the headlamps, you'll be able to reach down there after you remove the black bezel from around the headlamp. The black thing is held on by 3 torx screws. Its a tight squeeze....... good time to get the "significant other" involved in auto repair :lol:
Be careful of your clearance with the hood and lamps raised. Some are very tight and can rub. I would raise the lights, pop the hood and then SLOWLY raise the hood checking for clearance problems. Same goes with lowering. Lower your hood SLOWLY!!
Old May 19, 2003 | 07:26 PM
CP's Avatar
CP
Default Re: Turn Signal Bulb Replacement (TexasRedZ06)
Will try it. How much bother would it have been to put an access panel in the bottom of the front facia??? :mad
Old May 19, 2003 | 07:28 PM
Diamond's Avatar
Diamond
Cruise-In II Veteran
Cruise-In III Veteran
I do the front start to finish takes me 4 minutes, no tools required. Helps when you own a body shop I guess. :D
Old May 19, 2003 | 07:39 PM
texasredc8's Avatar
texasredc8
Whine.Whine.Whine. :D
My 300Z had access panels in the bottom skirt. Very simple little things with plastic velcro closures. I guess GM just wants to make it difficult on us.
Old May 19, 2003 | 07:51 PM
Oldvetter's Avatar
Oldvetter
The C5 DOES have an access panel. That's how the shop manual tells you to replace the front turn signals.
Jack up that side of car, remove 4 or 5 screws and panel, reach in and replace bulb.
It sounds harder than it is, I have done it twice.
Old May 19, 2003 | 08:24 PM
vetdaddy's Avatar
vetdaddy
Default Re: Turn Signal Bulb Replacement (Oldvetter)
Changed both left and right fronts this weekend. Went through the brake cooling vent. Just push it back and down out of the way. Took a minute each.
To Turn Signal Bulb Replacement
