How do I set my low/high beams?
Old May 21, 2003 | 01:08 AM
Nimo's Avatar
Nimo
St. Jude Donor '08-'09-'10
Default How do I set my low/high beams?
I fail to find anything on this topic by searching.
- Any pointers?
Both mine were pointing to the ground and I adjusted them some, but I'm sure that there is a procedure to follow.
Thanks,
Nimo
Old May 21, 2003 | 08:16 AM
THRAP 42's Avatar
THRAP 42
Default Re: How do I set my low/high beams? (Nimo)
Nimo,
Hope this helps http://lighting.mbz.org/tech/aim/aim.html
later,
Old May 21, 2003 | 01:49 PM
Nimo's Avatar
Nimo
Default Re: How do I set my low/high beams? (THRAP 42)
That is a great link - Thanks.
Anyone know what the adjustment screws do?
- Up/down is controlled by one, but the other deos not seem to adjust anything?
Thanks,
Nimo
Old May 21, 2003 | 02:01 PM
THRAP 42's Avatar
THRAP 42
Nimo,
The lower one (I think) is the vertical and the upper one is the horizontal.
later,
Old May 22, 2003 | 06:28 AM
C5 Frederik's Avatar
C5 Frederik
Be careful when turning the screws/nuts for aiming. A lot of members cracked the plastic parts inside. Maybe you first try to put some WD40 on the area where the nut sits.
Frederik
Old May 22, 2003 | 03:15 PM
Nimo's Avatar
Nimo
Default Re: How do I set my low/high beams? (C5 Frederik)
Thanks for the hints Frederik and Thrap 42.
- I'll get this sorted this weekend.
Thanks,
Nimo :steering:
To How do I set my low/high beams?
