bone stock C5 6SPD dyno results
Old May 21, 2003 | 03:20 PM
dmcantrell's Avatar
dmcantrell
Default bone stock C5 6SPD dyno results
Hello,
I have read articles about GM and how they rate the HP of the stock Corvettes at the low end of the spectrum, to assure that any Vette that rolls off the assembly line meets the claims due to the variability from motor to motor. Today I took my 2003 C5 6SPD and had it dyno'd, just to see where I start before tinkering with it -- I got 306.6RWHP/326.3ftlbs. Is this average, good, poor?? Does anyone know?? Just curious.
Thanks,
--dc.
Old May 21, 2003 | 03:21 PM
Ben01C5's Avatar
Ben01C5
Default Re: bone stock C5 6SPD dyno results (dmcantrell)
In sig.
Old May 21, 2003 | 04:15 PM
Fast Mover's Avatar
Fast Mover
Default Re: bone stock C5 6SPD dyno results (Ben01C5)
I dynoed stock 304.9 and 324ft lbs. Your numbers are right on the money.
Autos will dyno around 300 or less
[Modified by BRADS C5, 4:16 PM 5/21/2003]
Old May 21, 2003 | 04:18 PM
ICULUKN-C5's Avatar
ICULUKN-C5
Default Re: bone stock C5 6SPD dyno results (BRADS C5)
:iagree:
Old May 21, 2003 | 04:30 PM
Avanti's Avatar
Avanti
If you take your rear wheel figures times the accepted multiplier of 1.15 to convert from rw to approximate flywheel performance, you'll see you are pretty much right on GM's published performance data for a 6-speed LS-1.
I doubt that this varies significantly from engine to engine, given today's machining methods and computerized engine controls. This isn't the '60's where it was as you suggest. If it were, Ford and Mazda wouldn't have been in such hot water when a couple of their products' performance didn't measure up to what was advertised.
Today, performance is too big a marketing ploy with such vehicles to risk under-reporting power in the market place. Even in the 'ol days it was insurance rates that dictated fudged factory figures more than anything else.
All the best. :yesnod:
Old May 21, 2003 | 05:37 PM
BLU-BY-U's Avatar
BLU-BY-U
multiplying by (1 + your driveline loss %) is not as accurate as dividing by (1 - your driveline loss %) when working with a RW number.
IE: 306 X 1.15 = 351.9
VS
306 / .85 = 360
This will yield the most accurate flywheel number.
Old May 21, 2003 | 06:06 PM
omattitude's Avatar
omattitude
Default Re: bone stock C5 6SPD dyno results (BLU-BY-U)
Just curious....what are the generally accepted losses for a 3.42 and SY3500 A4? :confused:
Old May 21, 2003 | 08:08 PM
jim2527's Avatar
jim2527
Default Re: bone stock C5 6SPD dyno results (omattitude)
It looks like there is a 12% loss with MN6 cars. 350HP less 12% is 308 which seems to be about the average RWHP you guys are getting. Using a 15% loss for manual and a 20% loss for autos is an old wives tales/rule of thumb. The correct way to determine loss is to do the math backwards. Every car has a different % of loss depending on drivetrain frictional losses. For the vette it seems like 12% for MN6 and 14% for A4's.
Old May 21, 2003 | 08:35 PM
402Sam's Avatar
402Sam
Got a A4 here and she dynoed stock at 302rwhp 320rwtq :yesnod:
Old May 21, 2003 | 09:05 PM
SideStep's Avatar
SideStep
In my sig....
:cheers:
Old May 21, 2003 | 09:22 PM
Kwiksilver01's Avatar
Kwiksilver01
Default Re: bone stock C5 6SPD dyno results (SideStep)
Two weeks ago at the vet show in Madison my car ran .
315rwhp / 335rwtq
Old May 21, 2003 | 09:28 PM
SideStep's Avatar
SideStep
Default Re: bone stock C5 6SPD dyno results (Kwiksilver01)
315rwhp / 335rwtq
Are those your before, stock, numbers??? Or after the BlackWing, gears and your other listed mods???
:cheers:
Old May 21, 2003 | 10:07 PM
MTWallet's Avatar
MTWallet
Check my sig for my numbers with only a Vortex & Corsa Indy. I can't wait to get my new G5X2 Cam, UD Pulley, LS6 intake and FLP's installed. I'm hoping for 420+ after a custom dyno tune.
Old May 21, 2003 | 10:08 PM
DevilDog II's Avatar
DevilDog II
Veteran: Marine Corps
Oldtimer
My stock 98 dynoed at 320 rwhp and 333 rwtq.
Old May 21, 2003 | 10:09 PM
John Shiels's Avatar
John Shiels
From: Buy USA products! Check the label! Employ Americans
How many miles on it?
Old May 21, 2003 | 11:29 PM
Dave68's Avatar
Dave68
These numbers can be deceiving. There are different types of Dynos and correction factors. STD-corrected numbers are normally higher than SAE-corrected, so don't assume everyone's car was tested using SAE correction. My car was tested on a dyno that used STD correction and I'll bet those who posted similar numbers did the same.
Old May 22, 2003 | 02:34 PM
123Gone's Avatar
123Gone
Default Re: bone stock C5 6SPD dyno results (Dave68)
See sig
To bone stock C5 6SPD dyno results
Old May 22, 2003 | 02:54 PM
SteveL2's Avatar
SteveL2
I think you're right in the bell curve. Mine, stock and with a Vortex rammer air box, and 3.73 gears, dyno'd at 314 rwhp. I don't recall the torque, but I think it was lower than yours. :seeya
Old May 22, 2003 | 06:04 PM
Joe's Eray's Avatar
Joe's Eray
Put some miles on that new Vette of yours and break her in more. I am betting that you will get even more horses once she is broken in. :)
Old May 22, 2003 | 06:10 PM
Cajun @ Edgyvette's Avatar
0Cajun @ Edgyvette
Former Vendor
St. Jude Donor '07-'08-'09-'10-'11-'12'-'13-'14-'15
Default Re: bone stock C5 6SPD dyno results (MTWallet)
Just had to tell you. That vert is one of the best looking vettes I have ever seen :yesnod: :yesnod: very :cool: GOTTA GET ONE OF THOSE :auto: :cheers:
