noisy fuel pump?
Old May 21, 2003 | 11:54 PM
c5&r1 4fun's Avatar
c5&r1 4fun
Default noisy fuel pump?
has anyone had problems with noise, buzzing
from their fuel pump
is this just a normal thing on a corvette
tried the general discussion forum
maybe better luck here
Old May 22, 2003 | 12:08 AM
Richin Chicago's Avatar
Richin Chicago
Default Re: noisy fuel pump? (c5&r1 4fun)
They certainly aren't quiet. Also there is 2 of them because of the saddle tanks.
Old May 22, 2003 | 01:58 AM
C5BlkVette's Avatar
C5BlkVette
St. Jude Donor '03 thru '08,'16,'18,'21-'22,'24
I've read some threads about that and the conclusion is that they are normal for 97's? :confused:
Andy
Old May 22, 2003 | 05:33 AM
C5 Frederik's Avatar
C5 Frederik
On my ´98 coupe it was replaced in ´00 under warranty. The old one was very loud, the new one I can hardly hear.
Frederik
Old May 22, 2003 | 12:55 PM
c5&r1 4fun's Avatar
c5&r1 4fun
Default Re: noisy fuel pump? (C5 Frederik)
thanx for input
just came from the dealer
service tech said it sounded normal
how did u get them to fix it under warranty?
i told him that it was a service bulletin item
but he explained that does not mean that replacement is covered under warranty
i guess i just got to turn up the volume on the awesome stereo
Old May 22, 2003 | 10:36 PM
Bill Dearborn's Avatar
Bill Dearborn
97s, 98s and I think some 99s had very loud fuel pumps. After the redesigned fuel pump became available those owners that had the earlier cars could get them replaced under warranty as long as the warranty had not expired. I had the pump in my 97 replaced in the fall of 99. The redesigned pump may be noisy to some but if you compare it to the early pump then it is absolutely quiet.
Bill
Old May 22, 2003 | 10:56 PM
c5&r1 4fun's Avatar
c5&r1 4fun
Default Re: noisy fuel pump? (Bill Dearborn)
any suggestions on how to convince them that its a warranty issue
my exteded warranty runs out tomorrow thats why i took it in
like i said the service guy said it was normal and not a warranty issue
Old May 23, 2003 | 12:02 AM
bowtiebandit's Avatar
bowtiebandit
Most extended warranties wont cover components that are noisey only failed components. It's all in how it is "sold" to them.
FUEL PUMP NOISE COMING FROM PUMP/TANK #83-63-10 - (04/28/1998)
SUBJECT: FUEL PUMP NOISE COMING FROM FUEL PUMP OR FUEL TANK AREA [loz ] (REPLACE FUEL PUMP ASSEMBLY)
MODELS: 1997-98 CHEVROLET CORVETTE [loz ] BUILT PRIOR TO VIN BREAKPOINT 07561
CONDITION:
SOME OWNERS MAY COMMENT ABOUT A NOISE COMING FROM THE FUEL PUMP OR FUEL TANK AREA.
CORRECTION:
REPLACE THE FUEL PUMP ASSEMBLY. A NEW PARTS KIT (#12455734) HAS BEEN RELEASED TO CORRECT THIS CONDITION.
To noisy fuel pump?
