AIR pump throwing codes? Thinking about disconnecting it?
Old May 22, 2003 | 07:59 PM
Vinzvette's Avatar
Vinzvette
Default AIR pump throwing codes? Thinking about disconnecting it?
Ive heard just by disconnecting it can stop the codes. Mine needs replaced but I dont want to pay for what is almost useless. Does anyone know for sure and can anyone tell me how to locate it so that I may perform this operation. Thanks, Vince
Old May 22, 2003 | 08:10 PM
see5's Avatar
see5
Default Re: AIR pump throwing codes? Thinking about disconnecting it? (Vinzvette)
You can pull the fuse but then you will throw code. I edited it out. You should block the air tubes on the manifolds.
Old May 22, 2003 | 08:30 PM
AC54ME's Avatar
AC54ME
CI 6-7-8-9 Veteran
CI-VI Car Show Winner
St. Jude Donor '07-'08-'09-'10-'11-'12-'13
What codes are you getting (i.e. P0410)? Will make a difference in what you determine to do as a 'fix'. Please post the code(s).
Old May 22, 2003 | 10:09 PM
Vinzvette's Avatar
Vinzvette
yes P0410
Old May 23, 2003 | 10:41 AM
UtahVince's Avatar
UtahVince
It is in front of the left front wheel, behind a plastic panel. You'll need to get the front end in the air a bit (ramps are good). It's easy to disconnect/remove. I had no problems with codes when I disconnected mine.
To AIR pump throwing codes? Thinking about disconnecting it?
