Lowering the front end
Old May 22, 2003 | 11:13 PM
brooksdl1's Avatar
brooksdl1
Default Lowering the front end
I've heard folks talking about lowering the front end by an inch or two without having to do any modifications. How is it done?
Old May 22, 2003 | 11:40 PM
sindows98's Avatar
sindows98
Default Re: Lowering the front end (brooksdl1)
YOu can lower front and rear with the suspension bolts just get a hex wrench and lower it. YOu can go 2" front and rear
Old May 23, 2003 | 12:35 AM
MTWallet's Avatar
MTWallet
Here is a post I made where a guy wanted to raise his car back up to stock height due to rubbing of the front air dam. Just look at the pictures and then look under your car and you will see exactly what to do. There is also a Tech Tips section with good descriptions also.
http://forums.corvetteforum.com/zerothread?id=567472
Old May 23, 2003 | 08:37 PM
Racer's Avatar
Cruise-In III Veteran
St. Jude Donor '11
Default Re: Lowering the front end (sindows98)
You cannot lower 2" without cutting the factory front bushings and getting longer replacement bolts for the rear. :cheers:
Old May 23, 2003 | 11:18 PM
kwik8racr's Avatar
kwik8racr
Default Re: Lowering the front end (racer44)
:iagree: You may get an inch without cutting anything, but that's it! My car is pretty well "slammed", and it is only a 2" drop.
Old May 24, 2003 | 01:43 AM
SlumpinC5's Avatar
SlumpinC5
Default Re: Lowering the front end (kwik8racr)
kwik8racr, your car looks absolutly awesome! That paint looks soo good on that car! Very very nice job. :thumbs:
To Lowering the front end
