HAL adjustable shocks on 2" Lowered Vette
Old May 24, 2003 | 08:29 AM
Sportsdude's Avatar
Sportsdude
Default HAL adjustable shocks on 2" Lowered Vette
Any owner with this set? Setting the shocks at lowest soft mode - will this make the ride more comfortable than Bilstein sports? Since the car is llowered, will the shocks bottom out? :confused:
Old May 24, 2003 | 10:05 AM
SwissVette_Joe's Avatar
SwissVette_Joe
Default Re: HAL adjustable shocks on 2" Lowered Vette (Sportsdude)
TTT for you
......and asking for some appreciated replies as well from the experts here around.
Thanx in advance for any detailled Figures and Facts. Also : where to buy by best price (Shawn, THE LAPD ??), as my F45 setup is nearing the live expectations.......as far as the recent RTD-Damper check goes. Car still under warranty.
Joe. :seeya
Old May 24, 2003 | 01:13 PM
Umrswimr's Avatar
Umrswimr
From: Overwhelmed as one would be, placed in my position.... DFW, TX
St. Jude Donor '05
1) Since these shocks are not gas-charged like the stockers or Bilsteins, they WILL lower your car from the stock height. If you've already lowered the car, prepare for it to go even lower. Mine dropped about 3/4" just chaning the shocks
2) With the stock FE1 suspension, my car will bottom out over big bumps at speed with any setting below about 3. However, this is pretty rare. I run mine at about 6 or 7 on the street with no bottoming issues.
3) I've had two QA1 shocks rebuilt under warranty in less than a year and less than 20,000 miles. Just an FYI.
Old May 24, 2003 | 02:24 PM
Sean03's Avatar
Sean03
are the shock bodies shorter? do you get more travel with these shocks?
Old May 24, 2003 | 06:51 PM
Austrian Vette's Avatar
Austrian Vette
Mine is lowered big time.
And I have it 7 front and rear.
I like it how it is now.
The shocks allone really lower the car.
And yes, they are shorter bodies than the stock ones.
Michael
Old May 25, 2003 | 11:04 AM
ToplessTexan's Avatar
ToplessTexan
Cruise-In II Veteran
Default Re: HAL adjustable shocks on 2" Lowered Vette (Umrswimr)
What was wrong with them and was a cause of failure identified? Do you happen to know what the cost would have been after warranty? Some salesman once told me expected service life was 100k mi. :rolleyes:
Sportsdude, I concur with the comments already made, particularly those related to lowering due to shocks alone. There was another thread concerning adjustable shock options from a few days back that might have some good info to think about.
Old May 25, 2003 | 01:54 PM
2000^C5's Avatar
2000^C5
From: My barber didn't know when to quit... Do you?
Default Re: HAL adjustable shocks on 2" Lowered Vette (ToplessTexan)
See sig, I have the car that low with HAL shocks, keep them at 4 in front and 6 in back for daily driving. Car got a little lower after I put them on. Had them for 20,000 miles now and I love them.
Go for them, they are super easy to adjust, just reach behind each wheel, takes less than 10 seconds after a few times of practice.
Old May 25, 2003 | 01:59 PM
Sean03's Avatar
Sean03
Default Re: HAL adjustable shocks on 2" Lowered Vette (2000^C5)
does your car bottom out at that height? when i have my car that low it rides really harsh and bottoms out in the rear. with the stock shocks i only have about 3/8ths" travel before the car hits the bump stops. how much shorter are the hals?
Old May 28, 2003 | 11:05 AM
2000^C5's Avatar
2000^C5
Default Re: HAL adjustable shocks on 2" Lowered Vette (Sean03)
No, I don't bottom out.
Old May 28, 2003 | 01:15 PM
Flyin'Brian's Avatar
Flyin'Brian
Cruise-In I Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
They are not shorter than the stock shocks or the Bilsteins
Old May 28, 2003 | 01:29 PM
Dylan Savage's Avatar
Dylan Savage
Default Re: HAL adjustable shocks on 2" Lowered Vette (Flyin'Brian)
Brian, C5Stein posted a picture of these shocks next to a Bilstein (I believe?) showing the shock body was significantly shorter. Let me see if I can go find it.
EDIT: Oh well I can't find it. I still saw it though :) Maybe one of the other guys can chime in here.
[Modified by Dylan Savage, 12:46 PM 5/28/2003]
Old May 28, 2003 | 02:29 PM
Sportsdude's Avatar
Sportsdude
Default Re: HAL adjustable shocks on 2" Lowered Vette (SwissVette_Joe)
Swiss - I have a 2002 Vert with F45. Extreme Motorsport is installing the HAL adjustable for me so I can lower the car about 2". I was told that if I wanted to revert back to F45, it's not a difficult task.
Old May 28, 2003 | 02:36 PM
Umrswimr's Avatar
Umrswimr
St. Jude Donor '05
Cause of failure wasn't identified- they just told me that they replaced the valving and some other little stuff. They never said how much it would cost to replace, but I got the impression that it wasn't cheap.
My $0.02- go for the Koni SA's. :leaving:
Old May 28, 2003 | 06:36 PM
Flyin'Brian
Cruise-In I Veteran
Default Re: HAL adjustable shocks on 2" Lowered Vette (Dylan Savage)
I have the QA1s on my car and they are not shorter than the Bilsteins I took off. You need to measure the whole length extended not just the body of it. :yesnod:
Old May 28, 2003 | 07:03 PM
SwissVette_Joe
Sportsdude
Thanks for your complementary informations re HALs.
Otherwise, my question re "where to buy best" remains still open. Could someone pls chime in to give more infos about actual pricing conditions over the market. Anyone of the highly respected Supporting Tuners and/or Vendors ?
Thanks for the light.
Joe. :seeya
Old May 29, 2003 | 11:05 AM
ToplessTexan
Too late... I've had HALs on for over a year. I have started to think about options though.
Swiss, I think I gave about $860 US. Should not be hard to find them offered for that.
Old May 29, 2003 | 01:10 PM
Sean03's Avatar
Sean03
there are 2 problems with the konis if you have a lowered car. 1. they are just as long as the stock shocks, so if you have your car lowered 2" your going to bottom them out all the time. and 2. they are gas charged and will actually raise up your car almost 1/2" from where you had it set with your stock shocks.
To HAL adjustable shocks on 2" Lowered Vette
Old May 29, 2003 | 04:31 PM
C5stein's Avatar
0C5stein
Former Vendor
Thanks Dylan,
Hey Brian,
The QA1s (HAL) shocks that we sell for a C5 are 1" shorter than Bilstein Sports both front and rear. We don't sell the regular QA1 fronts as they list in the catalogue because it is the same height as the Bilstein Sport, and most of our customers want to lower the cars.
We have a GP on our Web site for the QA1s at $899.97
We have then instock and ready to ship.
I really like them in combination with the Z06 or Z51 springs and sway bars (which by we also have in stock).
I like the QA1s on the street set on 5. They are so easy to adjust that you will find it very easy to tailor them to you driving style.
I urge people not to make the shock do the springs work by running them extra stiff to make up for a soft spring. As UMRSWMR can attest, the shocks just don't hold up in that configuration.
This is the primary reason why we are developing an economical coil over package using the QA1 and coil over springs. It turns out that our setup is less money than you would spend, buying Z06 springs at the Chevy dealer and adding them to the QA1 shock package. For $1699 our coil overs are a smoking deal. Now on the other hand, if you can round up some Z06 or Z51 springs used, those with the QA1s would be more economical.
Any questions, just give me a call.
Old May 29, 2003 | 04:49 PM
Sean03's Avatar
Sean03
Default Re: HAL adjustable shocks on 2" Lowered Vette (C5stein)
do you have a site c5stein?
Old May 29, 2003 | 05:17 PM
Sportsdude's Avatar
Sportsdude
I'm interested in the QA1, please send web site.
[Modified by Sportsdude, 11:27 PM 5/29/2003]
