Ok...Houston we have a problem....spark plug thread potentially buggered
Old May 24, 2003 | 10:33 AM
SnowyATX's Avatar
SnowyATX
Default Ok...Houston we have a problem....spark plug thread potentially buggered
All,
While installing a new plug I think I may have buggered the first thread or so on the front/passenger cylinder. I have tried several plugs and I cannot get them started. I believe one of my attempts may have "screwed" me.
Anyhow, I would like some advice ASAP as to how to proceed from here. I'm a DIY'er (although in this case I may regret it!) so this may be my project for the long weekend. Any advice is appreciated. :cry
Old May 24, 2003 | 10:44 AM
RWhite's Avatar
RWhite
Default Re: Ok...Houston we have a problem....spark plug thread potentially buggered (PewterC5)
Maybe go to one of the auto stores (Pep Boys, etc.) and they may have something for you to rent (or buy) to restart the thread.
Old May 24, 2003 | 10:45 AM
SnowyATX's Avatar
SnowyATX
Looks like there are thread chasers out there than can be used to resolve my problem. Anyone used the type the expands in the hole and can be backed out to clean the first several threads?
Old May 24, 2003 | 11:19 AM
BlackZ06's Avatar
BlackZ06
I haven't tried any of the thread "cleaners", but here are a couple of things to keep in mind:
1) Do your best not to get any metal pieces inside the cylinder. As you most likely already know, they can cause problems should they get lodged inside the cylinder.
2) Always insert a spark plug by hand. Starting them with a wrench can lead to a crossed thread situation as it is too easy for the wrench to overpower the thread. Once you've got the plug inserted and have turned it by hand for several turns, then put the wrench on it to tighten it.
Best of luck,
Steve
Old May 24, 2003 | 03:13 PM
c5freak's Avatar
c5freak
Default Re: Ok...Houston we have a problem....spark plug thread potentially buggered (BlackZ06)
Be careful with a thread chaser. Metal shavings and cylinder heads don't mix.
Steve's right. Never use anything but your hand to start a spark plug in an aluminum head.
You may have to remove the cylinder head to repair the bad thread. Been there, done that.
Good luck.
Old May 24, 2003 | 03:30 PM
SHOWTIME!'s Avatar
SHOWTIME!
Default Re: Ok...Houston we have a problem....spark plug thread potentially buggered (c5freak)
If you have compressed air blow the hole out by sticking a hose into the cylinder. This way the air blows outward. Make sure the valves are closed.(TDC)
Next put alot grease on the threads and use a thread chaser.
Then insert a hose into the cylinder and blow air into the hose so the air blows out.
Spray with brakekleen and blow it again.
DONE
Old May 24, 2003 | 05:13 PM
SnowyATX's Avatar
SnowyATX
All,
Corvette184 gave me the tip of the century....see the tool here: http://www.starrproducts.com/newproducts.html called back-tap. It worked great. I had to drive 3hrs to get one (a Napa warehouse)...I couldn't sit around all weekend to wait for one to show up on Tuesday. She's up and running again...wheeeeww...what a sinking feeling that was. I've changed plugs hundreds of times...not sure how that happened....carelessness I guess. Now its time to go to my neighbors mud-bug boil and drink some beer. :party:
Old May 24, 2003 | 05:26 PM
SHOWTIME!'s Avatar
SHOWTIME!
that Back-Tap is sweet ! :thumbs:
Old May 24, 2003 | 07:41 PM
Sure To PleaZ's Avatar
Sure To PleaZ
That's a great tool! :cheers:
Old May 24, 2003 | 11:11 PM
chuckster's Avatar
chuckster
That is the sweetest tool!!!!
Did you watch the video... :smash: :smash: :smash:
Old May 25, 2003 | 02:34 AM
C5stein's Avatar
0C5stein
Former Vendor
I guess I'll be picking that up for the shop.
It isn't like I bugger up plug threads or anything, but sometimes I get a call from a customer that has exactly the same delemma that you had.
I'm lucky, the napa regional warehouse is only one offramp away.
Great find.
It is like the Split Dies that I got off of the Snap-on truck that have a hinge built in, so you spread them open and place them down on the good threads, place a tapered socket over it, and back it off, correcting the screwed up threads. I use it almost every time I need to take Hotchkis sway bar end-links off.
Old May 25, 2003 | 09:00 AM
Jim 47's Avatar
Jim 47
Thanks to you, PewterC5 and also to Corvette184 for the great link to some unique tools.
Jim Helm
Old May 25, 2003 | 10:40 AM
bowtiebandit's Avatar
bowtiebandit
All,
I use that tool all the time at work. I dont remember who makes the one I use but I proabably got it from Snap-On. I have never had a problem with getting shavings in the engine when using the above mentioned tip of using grease to trap them and it is a definite lifesaver for both the customer and myself. :thumbs:
Old May 25, 2003 | 12:34 PM
SnowyATX's Avatar
SnowyATX
Default Re: Ok...Houston we have a problem....spark plug thread potentially buggered (bowtiebandit)
Yep, it really saved my ****. Instead of grease I covered it real well with anti-seize as I was going to need some in the hole anyhow. :cheers:
Old Dec 27, 2010 | 06:26 PM
Ahmer's Avatar
Ahmer
Thanks for the info guys. This will likely be my project in a few months.
To Ok...Houston we have a problem....spark plug thread potentially buggered
