Missed shift 3rd to 4th need help with .....
Old May 27, 2003 | 08:54 PM
97vette's Avatar
97vette
Default Missed shift 3rd to 4th need help with .....
Friday I was pulling redline in third gear missed the shift to 4th and ended up in second ! What a rush. Melded the clutch I assume I reached the limit of the clutch's ability, better than a motor.
so I need help with finding and replacing the clutch m/c , suggestions on new clutch. It was a center force clutch/pressure plate w/ steel billet flywheel.
in my opinion I think the reason for the missed shift was two fold the B/W shifter and the clutch Hydraulics :flag
[Modified by 97vette, 9:00 PM 5/27/2003]
Old May 28, 2003 | 01:33 PM
STEPHEN H. SMITH's Avatar
STEPHEN H. SMITH
Default Re: Missed shift 3rd to 4th need help with ..... (97vette)
Man, been there done that!
Better do a compression check for bent valves or push rods.
You can spend more money, but Luk Pro Gold PN# 04-903 with
Alu. flywheel kit. Some ask $795 I bought mine for $680 from Dial-A-Clutch, talk to Tom Storey. If you want background on this clutch call 1-888-462-2739 and ask for Tom Haus.
You will also want to change to the 2002-3 Slave and Master Cyl. Try Pace Performance GM Parts dealer, or GM Parts Direct.
Old May 28, 2003 | 01:54 PM
CP's Avatar
CP
Melded the clutch
WTF is melded? :confused: I have never heard of that word.
Old May 28, 2003 | 02:20 PM
vettedevil's Avatar
vettedevil
Default Re: Missed shift 3rd to 4th need help with ..... (CP)
Melded the clutch
relax, typos happen. :p:
Old May 28, 2003 | 02:49 PM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
While you're at it, how about a suggestion for a new shifter... a HURST. I haven't missed a gear since I installed mine.
[Modified by leadfoot4, 2:49 PM 5/28/2003]
Old May 28, 2003 | 10:02 PM
99 The Hard Way's Avatar
99 The Hard Way
Default Re: Missed shift 3rd to 4th need help with ..... (leadfoot4)
Looks like he has the ripper already....
Old May 29, 2003 | 06:49 AM
leadfoot4's Avatar
leadfoot4
Default Re: Missed shift 3rd to 4th need help with ..... (99 The Hard Way)
Didn't see that, as the signatures were "off".
To Missed shift 3rd to 4th need help with .....
